Results 1 to 15 of 21
Thread: Been lurking since 2010. FINALLY its going to happen!
    Nov 2010
    Utah
    Talking Been lurking since 2010. FINALLY its going to happen!
    https://imgur.com/a/jTd6CQi
    Living in my neck of the wood is very hard for a Marauder fan. The number of vehicles here are so low no one even knows what they are unless they are a very classy sort of person. Last year I had my dream almost come true. A lowish mile(120k) Silver MM showed up in my local classifieds. I mean the full dream. It was owned by the gentleman's grandfather and cuddled and protected its whole life. Now for the sad part I had just bought a home a few months prior and it couldn't be a worse time to buy anything. Fast forward one year of regret and complaints that I missed my opportunity. My wife was very patient to endure that.
    I just happened to get a small raise at my job and I happen to look again. I find again a Silver MM I contacted him and ask how long hes had it. Says a year and bought it after the mans grandad passed away. BOOM same one! Well coming this Tuesday I will be finally be a member.
    Aug 2010
    Southern NJ - Exit 4
    Congratulations and welcome! What year is the SB?
    Sent from my SM-G900V using Tapatalk
    Nov 2010
    Utah
    SB? its a 2004
    Lots of acronyms here...SB is Silver Birch
    DTR = Dark Toreador Red
    DBP = Dark Blue Pearl
    Aug 2012
    Kansas City
    Congrats. Awesome story good for you!
    Neil
    2003 Mercury Marauder - SB/LF
    Nov 2012
    Sacramento
    Timing is everything!
    Oct 2008
    Massachusetts
    Congrats, it looks real nice!
    .... And JPB = Just Plain Black !!
    Jun 2015
    O'Hare IL
    Funny story. Welcome
    Good to hear! Those silver birches are nice! Ask me how I know 😂
    Change all the fluids, fuel filter and don't forget the brake fluid too!!!
    Motorcraft oil filter, synthetic 5w20 oil
    Trans is atf with mercon 5 , power steering takes the same fluid as the transmission. Reuse the oem trans gasket. Not kidding
    Rear diff, 2 - 2 1/2 quarts of synthetic 75w /140 fluid with posi additive.
    If the brakes feel crappy, just go with the big brake kit located thru here, world of a difference.
    Now that the fluids are done, clay bar the entire car including the trim last, and seal it with ceramic
    Now you will be forever in love with it 😍
    Nov 2012
    Sacramento
    All above... And If you can't swing the cost of the big brake kit now, at minimum buy the custome fitted stainless steel brake hoses and exchange-replace brake fluid and bleed bleed bleed the brakes. Amazing difference for minimal cost.
    Beautiful car!
    Jan 2008
    Shell Beach
    Congrats and Welcome! You got great taste!
    Silver Birch Society
    "I hear and I Forget
    I see and I Remember
    I do and I Understand"
    Quote Originally Posted by Bluerauder View Post
    For the life of me I couldn't remember the acronym for black...thanks, Charlie!
    Welcome aboard!
    Clean SB Marauder.
    Just vacationed out in Moab....Utah is a gorgeous place!
    Feb 2015
    South Florida
    Welcome to the site
    Righteous Indignation
    03 300A
    4055 of 7838
    4054 of 7093 in Black.
    Born 8/23/02
    Adopted in 1/15
    SOLD
  1. Lurking!
    By hippiericky in forum Community Discussion
    Last Post: 06-09-2011, 01:24 PM
  2. another marauder owner (newbie lurking!)
    By shami02 in forum Community Discussion
    Last Post: 02-10-2006, 09:20 AM
  3. Whats lurking in YOUR tree?
    By MAD-3R in forum The Lounge
    Last Post: 12-07-2005, 03:06 PM
  4. Crown Vic owner lurking
    By Paul Anderegg in forum The Lounge
    Last Post: 08-03-2003, 05:38 AM
