MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 12-06-2018, 10:33 PM
IndyMerc IndyMerc is offline
Member
Trader: (0)
Junkyard Crank Options
So after searching my local pull a part they have a ton of vehicles, but no lincoln marks or cobras.
boat loads of other fords, from explorers, mercury moutaineers, crown victorias, lincoln towncars and contintentals.
is my best option a 3v crank from an 07 explorer? I was thinking of snagging a 3 valve bottom end, using the crank for now and the 3v block for an all out turbo build over time. are these an easy mod with the 4v heads?
anyway I know I am off topic with that but couldnt really find a comprehensive list of compatible parts from other ford vehicle years. perticularly cranks and bottom ends.
just the obvious stuff pops up that is rare and usually gone by now.
  #2
Old 12-07-2018, 02:43 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
If doing a power adder build, I would buy a new forged crank, only forged crank I'm aware of is the cobra. Go on eBay or SVT forum
__________________
  #3
Old 12-07-2018, 06:40 AM
Turbov6Bryan's Avatar
I miss whitey here
Trader: (5)
I would just buy a three valve engine and put the four valve heads on it and run it. Double triple quadruple check that the vehicle you were buying the engine from his wrecked because more than likely if it's not correct it had engine failure or possibly had transmission issue.
If you were just looking for a crank, I believe you could probably find a used good crank that somebody already has pulled and just buy that
It's a ton of work to get that engine out of that explorer you will literally have to sawzall it out
__________________
03 BLACK 300A
03 BLACK 300A
04 Supercharged SILVER BIRCH
04 DTR
04 SILVER BIRCH
03 C.V. Sport SILVER FROST
04 Supercharged DTR
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Mach 1 8 bolt crank is it the forged crank? Turbov6Bryan Shop Talk 26 02-03-2016 10:06 PM
Junkyard Marauder Soxx35 Community Discussion 1 09-20-2015 07:32 AM
MM in Holland junkyard RF Overlord Community Discussion 9 08-15-2011 05:13 PM
Roaming the junkyard..... Ozark Marauder Shop Talk 7 08-07-2011 01:46 AM
Junkyard 31s? Motorhead350 Shop Talk 23 03-13-2011 08:55 PM
Powered by: vBulletin
