MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 04-20-2017, 12:12 AM
RedMerc04's Avatar
RedMerc04 RedMerc04 is offline
Senior Member
Trader: (0)
Marauder won't start: possible remote start/pats issue
Hi, I have an issue with my DBP 03 (I no longer have the car in my signature). Long story short, the car has a dealer installed Ford remote start and the car won't start. I just replaced the battery, as I figured that it was the likely culprit bc I had seldom used the car over the winter and it had not run for about three weeks prior to this problem. Upon replacement, the horn blasted and it wouldn't turn off. I disconnected it and attempted to start the car: I heard the fuel pump activating and the entire dash lit up when I turned the key but the car didn't turn over, not even a click... Both of my remotes, which appear to be Ford aftermarket items that came with PN: 2W7Z-19A361-BA, the remote start system, are completely useless and won't even lock or unlock the car (the batteries are fresh). I located a button under the dash and depressed it but nothing changed. I checked the 30 amp ignition fuse in the box under the hood and it looked okay. In the past the car sometimes had given me a problem when I tried to start it after manually unlocking it and using the conventional key.. to correct it, I would hit unlock on the remote and the car would turn over normally.
Further, there is a small LED light for the remote start on the dash beneath the instrument cluster that used to flash but no longer does. It appears as if the module is dead...
What should I do? Is there perhaps a fuse in the module that I'm missing? I really don't want to have to tow this thing!
Thanks,
Matt
__________________
Reinhart tune, NGK TR6 Plugs, 180 Degree stat,EMP/ Stewart Water Pump, K&N Aircharger, Cobra Exhaust, Megs Delete Tips, Flowmaster 40 Series Delta Flows, 4.10 gears, COP Connectors, Underdrive Pulleys, PHP Intake Spacer, 255/55/18 KDW2 Rears, Powerslot Rotors, Hawk Pads, TCI Deep Trans Pan, Ford Racing Girdle
  #2
Old 04-20-2017, 07:10 AM
GoldPanther's Avatar
GoldPanther GoldPanther is offline
Senior Member
Trader: (0)
Check if there's any fuses in the remote start module somewhere under the dash. Usually there's always at least one or two for any aftermarket remote start system even if it's ford.
__________________
  #3
Old 04-20-2017, 08:20 AM
fastblackmerc's Avatar
Trader: (75)
Quote:
What ^^^ he said.
Is there any documentation that you have that says how to "marry" the remotes to unit?
__________________
  #4
Old 04-20-2017, 11:23 AM
RedMerc04's Avatar
Senior Member
Trader: (0)
I checked the inside of the module and all of the fuses inside are good. No, unfortunately I don't have anything, I'm the third owner and it never made it to me. What is odd is that the little LED below my instrument cluster isn't flashing. When I turn the key, the PATS LED on top of the dash stays solid red and then goes out… this leads me to believe the module isn't getting juice, but I'm no expert.
__________________
  #5
Old 04-20-2017, 12:01 PM
Trader: (75)
Quote:
Are there any markings... part numbers, etc. on the modules or fobs? If there are maybe we can find more info.
__________________
  #6
Old 04-20-2017, 12:24 PM
RedMerc04's Avatar
Senior Member
Trader: (0)
The module under the dash has a PN of: 2W7J-19G367-AA. I had entered the wrong PN in my first post.
I looked at a few other Ford forums for info but nobody seems to have the problem that I am: their cars would at least start with the key. I attempted to program the remote start per the instructions I found on those sites but that didn't help. I don't think I have an issue with the PATS system bc the LED on top of the dash comes on, stays solid and turns off if I leave the key in the run position.
__________________
  #7
Old 04-20-2017, 12:34 PM
larryo340's Avatar
larryo340 larryo340 is offline
Now Marauderless :(
Trader: (3)
PATS sounds like it's working normally, if it's a Ford dealer installed system if you hold down that momentary switch while you turn the ignition key to crank it should crank then start. When you press down it bypasses the remote start install.
__________________
  #8
Old 04-20-2017, 12:53 PM
RedMerc04's Avatar
Senior Member
Trader: (0)
I tried that and got nothing, when I released the key I heard a subtle sound from somewhere in the engine compartment that sounded like a cricket--not a typical dead battery click but a very low sound- I was able to replicate it every time I released the key.
__________________
  #9
Old 04-20-2017, 01:43 PM
Senior Member
Trader: (0)
Oh I'm sure you have a stuck starter. Have someone cranking it while you hit it with a hummer.
__________________
  #10
Old 04-20-2017, 01:47 PM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
Here we go...
__________________
The Velvet Fog
2000 Grand Marquis GS
No name yet
Work In Progress
  #11
Old 04-20-2017, 03:33 PM
Senior Member
Trader: (0)
Quote:
Originally Posted by RF Overlord View Post
Here we go...
What's so funny?
This actually worked for me last time I replaced a starter. Who hasn't try this?
__________________
  #12
Old 04-20-2017, 03:41 PM
Pat's Avatar
Pat Pat is offline
Silverback
Trader: (4)
Me thinks he meant hammer, not Hummer. But a Hummer could be just as effective as a hammer.
  #13
Old 04-20-2017, 05:23 PM
Senior Member
Trader: (0)
Lol oops sorry
__________________
  #14
Old 04-20-2017, 05:27 PM
BAD MERC's Avatar
BAD MERC BAD MERC is offline
#2,187 out of 3,214
Trader: (3)
As a stereo and alarm installer since '93 I could fix it in a snap if you lived closer. BUT - if you remove the knee bolster and look under the column you'll see aftermarket wiring that is apparent and with some basic knowledge and common sense, you could remove it yourself. Let me know if you're interested and I'll assist any way I can.
__________________
'04 Silver Marauder w/ sunroof - HID lighting, JL Audio / Eclipse DVD/NAV/iPod/camera, 4.10's, 2" drop, Progard, Delete tips, Billet Pedals, BC4E dead pedal, Lidio Tune, Innovative chin spoiler, K&N CAI, TCE SS lines, Super40's, tinted tails, SS Inserts, Heinous Control Arms, Real oil gauge, Steeda UDP.
2004 Mercury Marauder
#2,187 of 3,214
997 in Silver Birch
448 with light flint interior
304 with heated seats
336 with sunroof
  #15
Old 04-20-2017, 11:34 PM
Pat's Avatar
Pat Pat is offline
Silverback
Trader: (4)
Smile Wiring
I think Zack was able to solve his wiring issue.
File Type: jpg 1D9A3D10-29D5-47A1-B2D4-32C9480BD11B_zpsonmnturi.jpg (94.1 KB, 33 views)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Big, Black, Bold - Marauder vs Impala in German magazine MGDriver Community Discussion 16 02-24-2017 03:12 AM
Mercury Marauder Rockets Up Sales Charts! Logan Community Discussion 30 01-16-2008 11:36 PM
Mercury Marauder Program Manager Chat - June 6th! Logan News 38 11-21-2006 08:36 PM
ATTN PC Techies - XP Start Up Issue - URGENT !. the_pack_rat The Lounge 18 08-03-2006 04:54 AM
Remote Start...Won't!! martyo Shop Talk 23 04-18-2003 05:38 PM
Powered by: vBulletin
