MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 04-20-2017, 09:30 PM
cashmonkey38's Avatar
cashmonkey38 cashmonkey38 is offline
Noobin' it up
Trader: (0)
Question Half of instrument cluster lights not working
Another random problem has popped up on the car. I switched to LED lights a few years ago. The ones I got were crappy and slowly starting going out after a year tops - the lights would flicker and flicker and eventually go all the way out. I am replacing all lights now, but when I replaced the illumination lights that went out in the instrument cluster, only 2 of them are working. I believe all of the warning lights are working, it's just the illumination lights. As you can see in the pic, only the one near fuel gauge and trip meter are working. Thus I can't see top of speedometer or RPM's at night.
If I take the fixture holding the bulb from a non-working section and put it into a working section, they light up fine, so does not appear to be bulbs or the bulb holders. Yes plugs are all the way in, jiggling things does not cause lights to light up either. Fuses all seem to be fine but I wouldn't think the illumination lights would be on a different fuse anyway?
Any idears?
__________________
Maraudin' for Vengeance!
  #2
Old 04-20-2017, 09:37 PM
Noobin' it up
Trader: (0)
Forgot pic
__________________
  #3
Old 04-21-2017, 05:06 AM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
LED bulbs only work inserted one way. Flip them 180*
They only work in other holes because the wiring is reversed.
__________________
  #4
Old 04-21-2017, 10:22 AM
fastblackmerc's Avatar
Trader: (75)
What justbob said and it looks like you need quality LED bulbs.
__________________
  #5
Old 04-21-2017, 12:32 PM
Noobin' it up
Trader: (0)
Hmm I had thought about checking that - the thing is that I replaced all of the lights in the car, and all of them are working fine except for the ones noted in the instrument cluster, so I figured surely I did not happen to only mismatch the ones in there? And then assumed they must be able to be put in either way - I will check and update if that's the fix, thanks for the replies
EDIT: That was it!!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Feed back tail lights not working but brake lights work Gerry24 Interior Electrical/Electronics 12 12-28-2016 07:02 PM
Interior lights & key pad not working LUCKY GENE Interior Electrical/Electronics 10 12-23-2016 03:20 AM
Adding an oil pressure idiot light, Part 1 drgnrdr33 Shop Talk 9 09-25-2008 06:00 AM
Marauder Instrument Cluster jsvic Other Parts/Misc. Wanted 0 09-01-2007 11:29 AM
Instrument Gauge Cluster and Speedometer blackf0rk Shop Talk 4 01-30-2006 12:28 AM
Powered by: vBulletin
