Results 1 to 5 of 5
Thread: Springs
    Jul 2007
    Clinton, TN
    Question Springs
    Anyone in the MD, DC, VA area know of a good suspension shop that would be able to cut the front springs of the Marauder the proper way? It was explained that the metal had to be heated (maybe?) to retain it's proper strength/tension.
    I've heard good and bad about the Eibach springs... do you think they would cut springs if they were sent to them? (dumb ? I know but, I figured I would ask anyway)
    Natalie
    Oct 2003
    Afhaggisland
    How about a welding shop?
    Saorsa gu Brath
    (Freedon Forever)
    Si vis pacem para bellum
    Μολὼν λαβέ
    (Come and take them)
    Stann saam of sterf allen
    (Stand together or die alone)
    Audentis Fortuna Iuvat
    (Fortune Favors the Brave)
    "THE BLACK BOMBER"
    Apr 2005
    The Pitt, PA
    Quote Originally Posted by SurfrsOtherToy View Post
    Natalie
    1) Make sure you cut both springs in the same spot.
    1.5) Hold the spring in a vise, to you're not chasing it around while trying to cut.
    2) Keep the cut location COOL. I used a water-soaked rag wrapped around the keeper side of the cut.
    3) Cut with a fresh cut-off wheel and a die grinder with plenty of pressure that won't run out during the cut. The faster you get through it, the less heat goes in the metal.
    4) Spray the exposed cut with etching primer, then with black paint.
    5) Replace the spring perch exactly as it was removed (assuming 1 full coil cut)
    Any decent auto shop has the needed tools. It's really not hard. Just take your time with the setup and have your tools and materials together.
    Make sure you use a proper spring compressor to remove the spring from the strut assembly.
    2013 Ford Taurus SHO
    #1649
    boi
    could probbly cut the rears with a razor blade
    Jul 2007
    Clinton, TN
    Cutting
    mmmkay.. I will def take that into consideration.... BTW, YOUR hood, is THE BOMB!! I wish would would come over and paint my truck.. I know, not a Marauder.
  1. Cut springs - yea or passé?
    By HwyCruiser in forum Community Discussion
    Last Post: 04-22-2005, 07:52 PM
  2. H&R progressive-rate springs for Marauder
    By studio460 in forum Community Discussion
    Last Post: 01-15-2004, 06:15 PM
  3. edelbrock springs and 255 tires?
    By darebren in forum Tires & Wheels
    Last Post: 11-05-2003, 02:30 PM
  4. Replies: 31
    Last Post: 07-29-2003, 03:40 PM
  5. Higher rate lowering springs
    By LightningVic in forum Community Discussion
    Last Post: 11-18-2002, 12:23 PM
