Off to a good start, beat the Jays 6-1.
Gonna be a good season!
If a good season is a 2nd place finish in the East to the Sox, then sure!
27-8
You couldn't be more wrong...............
https://www.google.com/url?sa=t&rct=...iheuJzjD7BrlOS
......and that's from last Oct. before they picked up Stanton.
My oh my...
Awfully quiet in here!!
Guess it’s best to be quite when your team is getting smoked by the loser Red Sox!
They'll never be smoked by the Sux. 27-8!
Don't count out the Orioles
We're setting records!!....
BTW: I think that Buck Showalter played a trick on Dylan Bundy last night...
Buck told Bundy to go out and throw BP....
and to make sure that
"all the pitches are taters down the groove"!
