MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 05-10-2018, 10:24 PM
03MERCMARAUDER's Avatar
03MERCMARAUDER 03MERCMARAUDER is offline
If your Gonna boost it, Boost it hard
Trader: (1)
Rough idle
So before the Nazis jump in I have done the searches and spent a good amount of time reading the different issues and fixes people have done. I recently purchased an 04 marauder off the boards here and it had a rough idle which bugs me. I love the car and do not regret the purchase at all but I have had one of these cars when they were new and it had a smooth idle even after a tune. Car I purchased has the a Lidio tune, older JLT CAI and 4.10 gear. When I first got the car I noticed it would surge when I left off the brake at a light. I was able to fix this by upping the idle RPM in drive but that has its draw backs. I even swapped the stock tune back into the car and still had the same issue.To date I have replace the plugs (proper gap) New OEM coils, motor craft Fuel filter, I cleaned the IAC as well and the MAF and still fight this idle issue. I can hear it through the exhaust even at idle. So what am I missing? Any words of wisdom from the veteran folks on this board? Appreciate any help
Joe
__________________
2004 SB
4.10's and a tune
More to come
  #2
Old 05-10-2018, 11:13 PM
BlackBeauty_bb's Avatar
BlackBeauty_bb BlackBeauty_bb is offline
Member
Trader: (0)
Rough idle
have you checked for any vacuum leaks?
  #3
Old 05-11-2018, 12:50 AM
musclemerc's Avatar
Senior Member
Trader: (27)
EGR valve is stuck open. Big ole vacuum leak
  #4
Old 05-11-2018, 02:16 AM
crownvic97's Avatar
crownvic97 crownvic97 is online now
Senior Member
Trader: (3)
When I bought my Marauder it had a rough idle as well. Replacing the plugs made no difference. A compression test showed low compression on cylinder 8. I’d suggest you do a test as well.
  #5
Old 05-11-2018, 04:50 AM
TooManyFords's Avatar
TooManyFords TooManyFords is offline
Action figures sold separately
Trader: (6)
As already suggested, either the EGR or your IAC. Just cleaning the IAC does not mean it will work correctly. Also, make sure you get the Ford one and not an off-brand.
Surging is excess air, so you also might want to get a can of starting ether and spray around the various hoses connected to the intake, and also around the intake runners by the heads as well. I bought a Marauder to put back together and it had a rough idle. Turned out the lower intake by #1 was cracked and it was afterwards I found out it also had a nitrous kit on it at some time. I found it with the Ether trick. I'm guessing it was not setup correctly and backfired which cracked the intake.
What you describe is most likely an easy fix. Keep looking and you'll find it.
  #6
Old 05-11-2018, 05:12 AM
blazen71's Avatar
blazen71 blazen71 is offline
I'm Your Huckleberry
Trader: (3)
When you spray the ether, the rpm's will increase if there is a vacuum leak cause the engine is sucking it in and burning it.
__________________
2004 300A Procharger #0010 P1SC, now D1SC
2003 300A Procharger #0017 D1SC (SOLD)
  #7
Old 05-11-2018, 06:37 AM
Marauderjack's Avatar
Marauderjack Marauderjack is offline
Senior Member
Trader: (13)
If you need a Brand New IAC Valve I have two made by Hitachi who made 'em for Ford according to Bob!!
PM me if interested!!
__________________
Member #1368
2004 Silver Birch...300A
#948 of 3213/#8787 of 11052
FIT "ProCharger" #0010
Real AutoMeter Oil Pressure Gauge
Addco Anti-Sway Bars
ScanGauge II In Dash
Nitto 295's On Widened Rears
Mach I Air Dam
  #8
Old 05-11-2018, 07:18 AM
Trader: (1)
Thanks for the suggestions I will give it a try today
__________________
2004 SB
4.10's and a tune
More to come
  #9
Old 05-11-2018, 07:24 AM
fastblackmerc's Avatar
Trader: (75)
Quote:
What ^^^^^^ they all said!
__________________
  #10
Old 05-11-2018, 12:03 PM
Trader: (1)
No vac leaks found using ether so guess I will look at replacing the egr and iac to see if that resolves the issue. Will also do a compression test this weekend. Other than the idle the car runs fine. Its just enough that you can see a shake to the motor and feel the car shake
__________________
2004 SB
4.10's and a tune
More to come
  #11
Old 05-14-2018, 10:53 PM
crownvic97's Avatar
Senior Member
Trader: (3)
Quote:
I wouldn't bother replacing any parts before doing the compression check. Its quick and easy and may save you from throwing parts at the problem.
  #12
Old 05-15-2018, 06:35 PM
Trader: (1)
Update. I tossed a known good egr valve on and no change to the rough idle. Plan is to do a compression check tomorrow. I put my x cal on the car and this time I had codes. Had code P0316 and code for cylinder 8 misfire. I swapped cylinder 1 COP with cylinder 8 and cleared the code. Fired the car up and still has rough idle and after a short drive same codes are back so cylinder 8 is where I will focus. Based on the research I have been doing I am afraid I will find low compression on cylinder 8 but I may be wrong. Stay tuned.
Joe
__________________
2004 SB
4.10's and a tune
More to come
  #13
Old 05-15-2018, 09:57 PM
crownvic97's Avatar
Senior Member
Trader: (3)
Joe
This is the exact same symptoms and outcome I had on mine. Misfire on 8 that stayed on 8 no matter what was changed. I’ll be hoping that you have a better outcome than me!
  #14
Old 05-15-2018, 10:00 PM
Trader: (1)
Quote:
Head have to come off your car?
__________________
2004 SB
4.10's and a tune
More to come
  #15
Old 05-15-2018, 10:03 PM
crownvic97's Avatar
Senior Member
Trader: (3)
Yes, I took it as an opportunity to upgrade however. You could pull just the driver side head and have the valve/valve seat repaired on 8 (assuming That’s the issue which is likely).
I bought some 9 thread heads, had a valve job and some porting done to them, and basically replaced everything other than the shortblock. Still not done!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
won't idle jb513 Shop Talk 11 08-23-2012 06:34 AM
Help Car won't idle MAROGER Shop Talk 2 05-09-2012 03:09 PM
Idle air (RPM) Pat Shop Talk 14 06-24-2011 12:59 PM
Idle Drops At Idle 2003CTMarauder Shop Talk 9 02-26-2006 01:04 PM
idle, now od nexstar7 Shop Talk 3 07-31-2004 05:24 PM
Powered by: vBulletin
