Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
Thread: cam trigger wheel phase altered by degreeing cams?
    Nov 2007
    San Jose
    Lowndex is getting some cam sensor error codes, maybe he can post the number. What could cause this?
    While degreeing the cams changes the angle of the camshafts relative to the crank and crank trigger, what does this do to the relationship between the crank trigger and cam trigger? What happens to the phase of the trigger wheel when the cams are degreed? My memory of the timing gear setup isn't sharp enough to remember how the trigger wheels are referenced to the crank. From what I remember from Livernois, I think they use Cloyes timing gears with the Ford Racing timing kit.
    When degreeing a cam, does the angle of the cam trigger wheel change relative to the crank? Maybe the computer is smart enough to notice a change in phase relationship between crank and cam signals and throw a code? Never heard of anything like this happening, but not too many here mess with degreeing cams.
    Lifespeed
    Jan 2015
    Mishawaka, In
    I’d say the timing needs redone, comp cams makes a 4v adjustable cam gear set, it’s good for up to 12* advance or retard. These gears make timing advances easier.
    https://www.lethalperformance.com/co...iABEgJFM_D_BwE
    Maryland
    Who degreed the cams? Does it seem to.run okay other then codes?
    601rwhp 592rwtq @19psi
    Jan 2006
    Northern California
    Quote Originally Posted by Seneca View Post
    KC at BRG Racing.
    Runs awesome.
    Jan 2006
    Northern California
    why is a speed, race shop asking cam degreeing errors? not being an a $$ here, but someone has been paying an awful lot of money to not have the shop figure it out. longest engine build in history of building motors, with price tag to boot
    This is about the Marauder ECU throwing an error codes (P1174, P1175) unfamiliar to the mechanic on duty. The wiring, connectors and fuses are all new, but have been double checked from ECU to sensor.
    Here is what I found with Google:
    http://p1174.obdcodes.me/mercury-marauder
    http://p1175.obdcodes.me/mercury-marauder
    Looking for Panther expertise! Whomever gives me the correct answer gets $$$!
    KC is on vacation in Montana. So, I can sit around two weeks and wait or get some help now from our members.
    Nov 2007
    San Jose
    That's a good question for Lowndex. Livernois didn't do the long block, right? KC assembled the heads to the block and degreed the cams?
    As far as I can tell the reluctor bump on the timing gear for the cam position sensor does not move with cam degree adjustments. The adjustment is at the interface to the cam, leaving the relationship between the crank sensor and cam sensor unchanged with cam adjustment.
    However, adjusting cam timing (or plain old making a mistake) by moving the chain off a tooth would change the relationship between the cam and crank signals.
    Lifespeed
    Jan 2006
    Northern California
    Correct.
    I will pass your input along.
    Nov 2007
    San Jose
    In the dinosaur days of pushrod big block Chevys it was not unusual to use not only the offset keyways to degree a cam, sometimes the chain was deliberately jumped a tooth to arrive at the right cam timing due to tolerances in manufacturing of the crank and cam.
    If the gear alignment is off by a tooth the crank vs. cam signal timing will be altered, even though the cam timing may (or may not) be degreed correctly. So it may still run well. The cam position sensor only needs to tell the PCM compression stroke vs exhaust, it doesn't need to be super accurate to fire the injector and coil correctly. Accuracy comes from the crank trigger.
    However, cars are supposed to use their sensors and computer to be somewhat self-diagnostic. I know for a fact if the timing chain in my 3.6L DOHC Cadillac V6 stretches beyond acceptable limits, it will detect it using the cam and crank signal relationship and throw a code.
    I guess there is a possibility your cam gear is a tooth off, and the PCM notices. I would like to get a better definition of those codes than that web link you posted, if possible.
    Lifespeed
    The Dirty South
    I degreed my cams the old fashion way by grinding and cutting new keys. Never had any issues with the triggers.
    I have 98 cobra cams FYI.
    Jan 2006
    Northern California
    A new error code reported: P0340.
    Nov 2007
    San Jose
    P0340 - Camshaft Position (CMP) Sensor Circuit Malfunction (Bank 1) The test fails when the PCM can no longer detect the signal from the CMP sensor on Bank 1.
    There is no listing in the service manual for P1174, 1175.
    Maybe swap the sensor for a known good one? While it is out rotate the engine to TDC on #1 and look through the hole for the trigger tooth.
    Lifespeed
    Nov 2009
    NH
    Any wiring harness chaffing on the back of the head? Never had issues after degreeing my aftermarket cams. Unless you have the TFS adjustable crank gears, the exhaust gear trigger position doesn’t change. It still wouldn’t cause codes unless something was really wrong. You have to remember, there’s a lot of ponies out there with the same cam/crank sensors running some crazy cams without these issues
    May 2009
    Moreau Island
    Call Mo's maybe Jeff has a thought.
    Jan 2006
    Northern California
    Thank you, all. I will try Lifespeed's idea. If not resolved, time to call a Panther expert: Mo.
  1. Regarding Info on Degreeing Cams
    By massacre in forum Shop Talk
    Last Post: 02-06-2017, 11:34 AM
  2. Cam Timing/Degreeing Cams
    Last Post: 04-15-2011, 05:16 AM
  3. Altered My Drivers Seat
    Last Post: 06-27-2010, 06:07 AM
  4. Project Bling Phase One
    Last Post: 06-11-2004, 05:36 AM
  5. New Stereo, Phase I
    By mrogerc in forum Community Discussion
    Last Post: 03-24-2004, 08:22 PM
