MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 11-08-2018, 03:44 AM
01MercGMLS's Avatar
01MercGMLS 01MercGMLS is offline
Member
Trader: (0)
Engine Coolant Temperature
So I'm having a bit of an odd issue in my opinion. It doesn't matter whether I start my car and let it run for 20 minutes before I leave or just start it up and leave. It takes about 8 miles of driving before the engine temperature comes up. Then, when I turn my heat on the temperature almost immediately drops back down to cold before slowly Rising back to normal. Then the oddest part... shutting the engine off long enough to fuel causes it to go back to cold as well. I would love to say it's just a sensor issue but when the temperature is reading cold I have no heat so it has to be the coolant temperature. What is happening here? Bad thermostat?
  #2
Old 11-08-2018, 05:17 AM
justgod's Avatar
justgod justgod is offline
Senior Member
Trader: (0)
Your thermostat is stuck open. Your coolant is flowing through the radiator too much releasing all the heat gained from the engine.
  #3
Old 11-08-2018, 05:31 AM
01MercGMLS's Avatar
Member
Trader: (0)
Quote:
That's kind of what I was thinking too. Thanks.
Any recommendations on what thermostat to get? As far as temperature goes...?
  #4
Old 11-08-2018, 05:58 AM
musclemerc's Avatar
Senior Member
Trader: (27)
NAPA 109
180*
  #5
Old 11-08-2018, 07:33 AM
01MercGMLS's Avatar
Member
Trader: (0)
Quote:
Originally Posted by musclemerc View Post
NAPA 109
180*
Thank you sir!
  #6
Old 11-08-2018, 08:08 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
Is this for a marauder? T stat not same for a MGM and a 180 temp will need a change in the tune to tell fan to come on earlier than the 195 stock stat.
__________________
  #7
Old 11-08-2018, 08:26 AM
01MercGMLS's Avatar
Member
Trader: (0)
Quote:
This is for my 2001 Grand Marquis
  #8
Old 11-08-2018, 08:29 AM
Weißbirke Plünderer
Trader: (11)
Napa 109 will not fit 01 MGM..a 180 tstat does zero good unless the pcm has been told to turn fan on at a lower temp.
__________________
  #9
Old 11-08-2018, 08:34 AM
musclemerc's Avatar
Senior Member
Trader: (27)
This is my go to tstat for DOHC engines tune or no tune.
I think your referencing a tune for colder plugs and tstat to run more base timing.
Just put one on a Mach1... Stock tune... Temps are fine...
  #10
Old 11-08-2018, 09:11 AM
Weißbirke Plünderer
Trader: (11)
Yes, you are right in my meaning. But he has a 2v motor, not a marauder, so different tstat
__________________
  #11
Old 11-08-2018, 01:13 PM
01MercGMLS's Avatar
Member
Trader: (0)
Yes. I'm currently driving a Grand Marquis. I was in desperate need of a car and while I wanted a Marauder I couldn't find one in decent shape fast enough. Ended up with a decent mileage 1 owner Marquis. A Marauder is on my wish list and will be in my garage soon. In the mean time I'm here getting good info and tips for when I do get it. Also, since the cars are built on the same Panther platform I can get some good info here for my MGM.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Normal Engine Temperature, All Stock mrhimself Shop Talk 21 10-25-2017 10:57 AM
FYI-Keep Your Engine Alive: The Importance of Oil Temperature GreekGod Shop Talk 1 03-22-2015 05:15 PM
Coolant Temperature Sensor Timw286 Shop Talk 13 09-07-2013 09:25 PM
Engine Oil Temperature FordNut Shop Talk 3 10-19-2009 02:48 PM
Engine Bay Temperature Pat Community Discussion 3 09-12-2006 01:38 PM
Powered by: vBulletin
