Results 1 to 15 of 21
Thread: Headlight off delay time
    Howell, MI
    Cool Headlight off delay time
    Just curious, My headlight off delay is a little bit short (I think). It seems to time out in about 18 seconds from vehicle shut off or innitiation from unlocking the door with the key fob.
    That amount of time isn't long enough to get into the car or away from it most of the time. kinda almost annoying. Is this normal? What are the times on other MM's
    This is the first auto headlight feature that I've had with Ford that doesn't have a time adjustment by the switch. Is this adjustable? Didn't see anything in the owners manual and the Service advisor is drawing a blank.....Thanks
    Tim,
    TheFlatlander
    1983 F100/Bronco-529ci "Flatlander Express"
    2005 F250 Lariat CC 6.0L 4X4-Charcoal Grey
    2002 F550 V10-Winnebago "Flatlander 550"
    1998 Grand Cherokee 5.9ltd (Two Identical)
    Southern Illinois
    Quote Originally Posted by Theflatlander
    I may be mistaken, but I thought the auto headlight delay was controlled by the dash light dimmer switch...ie...brighter the dashlights, the longer the delay. I dunno know where I read or heard that at, but it comes to mind.
    Let me know if it is true.
    Douglas
    Drives03Maraude Guest
    T-birds have what u are talkin about
    My buddies 94 bid had auto off lights like the MM, and it had a dimmer style switch above or below the interior light switch.....it is similar, that may be what u are thinkin of?
    Oh well just a thought....
    -Dennis Stiles
    My 2003 300a doesn't have any setting with the light switch to control the delay. I don't think that the dash dimmer switch is involved in this, that's just a dimmer switch. As far as I know, the auto headlamp function on the Marauder is fixed in terms of delay. Kind of a bummer. My '97 T-Bird had a seperate dial to allow you to adjust this.
    2003 Mercury Marauder
    2007 Lincoln Town Car
    1993 Crown Victoria LX
    Howell, MI
    The dimmer has no relation to the time delay. I'm pretty sure about that. (While we're on the dimmer there isn't much of a detent in the motion between full dash lights and interior light on...kind of poor design?)
    Going back to the origional post though, how long is the delay time on other Marauders? With mine being just short of 18 seconds and is that the norm?
    Also was looking since there is no dash mounted adjustment for the delay time if there was some "secret handshake" type of adjustment? Like how the annoying seat belt minder is turned off. Not everything is put in the manual-like for example that our vehicles actually have speed sensitive volume control or how to adjust it (addressed in an older thread)
    Tim,
    TheFlatlander
    Chicagoland
    I ran across this, look in the your car manual. I read something in the manual on how to make it a shorter or longer delay cycle. It just seem like a pain in the butt to me on how to do it, but it can be done.
    2003 Marauder 300A Owner
    Born 6/2/02
    Came home with me home 6/24/02
    [img]
    Howell, MI
    Been thru the manual and I must of missed it or it isn't published in the '04 version.
    Tim,
    TheFlatlander
    Derby City, KY
    Flatlander,
    My '04 DTR is the same as yours -> 18 sec. then shutoff as checked a few minutes ago.
    The dimmer below is in fact for the dash lights / cabin lights as stated in some of the replys. My '01 GM did have adjustable delay however.
    Long Island, NY
    My 2000 GM had the adjustable time delay. IMO the FMC saved a few $'s by deleting the time delay switch.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Howell, MI
    It's actually a different switch from the GM due to the MM having fog Lamps. Where is the time dely controled from, is it in the switch? and can it be modified?
    Tim,
    TheFlatlander
    Middletown, De.
    The delay is factory pre-set and there "IS" no adjustment.....
    Bob, USNavy Retired
    Chicagoland
    Ok class lets try this.
    1. Turn the headlamp switch to OFF.
    2. Turn the ignition to RUN and then back to OFF.
    3 Turn the headlamps switch to Autolamp position.
    4 Wait the desired amount of time for delay, then turn the headlamp switch to off.
    5 steps 1 to 3 need to be performed within 10 seconds.
    Hope this works.
    Born 6/2/02
    [img]
    Chicagoland
    does anyone’s overhead console buttons light up? At night I can't find the build-in homelink garage door button! On the 2003 Lincoln Continental the buttons light up in the overhead console so you can see what heck you’re doing.
    Born 6/2/02
    [img]
    Howell, MI
    Quote Originally Posted by tomd
    Hope this works.
    Tomd, Thanks for the info. I will try out tonite when I get back to the MM and report back results.
    Tim,
    TheFlatlander
    Howell, MI
    Nope neither does mine or any one elses. there was a thread in the recient past of somebody adding LED's
    Tim,
    TheFlatlander
  1. Marauder Has Good Showing @Drag Strip
    By sailsmen in forum Community Discussion
    Last Post: 10-04-2004, 05:05 AM
  2. Strike at FLM plant causes delay in MM delivery...
    By hitchhiker in forum Community Discussion
    Last Post: 03-28-2004, 09:02 AM
  3. Headlights delay
    By PAPAJOHN in forum Community Discussion
    Last Post: 11-15-2003, 10:56 PM
  4. Recent 1/4 mile time...
    By tvdone in forum Community Discussion
    Last Post: 08-05-2002, 04:33 AM
