Ok, have heard a noise, tough to describe, but I would have to say it sounds like a metal guard of some type rattling at WOT, doesn't do it all the time, no rhyme or reason. Recently removed the silencer and replaced it with rubber cover as in the silencer removal thread.
Had service tech ride along, he heard it as well, says he believes it is something vibrating such as a guard or shield. Definitely not in the engine(so he says).
Next oil change he will get under the car and check for any loose guards/shields.
If I had to describe the noise, would have to say it was similar to the noise one used to get on the older cars from the metal tube that extended down from the air cleaner into the exhaust manifold when the tube was loose.
Comments? suggestions?
BTW the silencer thing might just be a "red-herring"
No decrease in performance noted when it happens,,
car has 5,000 miles
