New noise
At 600 miles on the rebuild i started to hear a very hard to explain noise it sounded like a bad ac pump with every revolution you could hear it grinding metal like a clat clat clat real fast but it came and went with almost perfect timing lets say once the car started it took 1 to 2 min to start then would last maybe 60 to 80 sec then go away for 1 to 2 min and then back on like clock work. I started with everything in the belt drive and pulled the belt off started the car and it still happed but right before i turned it off it blew the pcv valve out of the valve cover and the next time after that that i tried to start it i heard a weird bang sound. so yesterday i pulled the motor and today started at the front cover thinking it was the chains i just got the harmonic balancer off and found that it was wearing into the front cover in a half circle on the bottom 180 to 360.
I think this is my problem but i just wanted to throw it out here if anyone has heard anything like this.
Any ideas on what would cause the pcv to blow off
Any help is appreciated
Thanks Tim
03 MM 10/7/02
5407 0f 7838
5406 of 7093 in Black
