Is there an upgrade for the sway bar and links on the Marauders whether it be a bigger sway bar are better links
Sent from my SM-J337AZ using Tapatalk
The fine print on that about end links:
Swaybar does not include new endlinks. Factory Ford endlinks are available in the drop down menu above if your originals are worn! We do not suggest anything but original as aftermarket endlink bodies may be too large and rub the spindle.
You can also take a look at Addco Sway Bars. Many members have installed them with great results.
https://www.mercurymarauder.net/foru...ad.php?t=25255
So is the ADTR sway bar bigger?
The Addco also reduces body roll and significantly tightens handling.
My car had addco sway bars and handles great
Joe
Sent from my SM-G955U using Tapatalk
2004 SB
4.10's and a tune
More to come
This is true... Funny thing is my 03 has Moog and they never showed signs of rub, I did the exact same setup on an 04 and the Moogs rubbed so we went with OEM and the issue was solved. My 03 didnt have lock collars installed the 04 has them. Never figured out why the 04 with collars and Moogs rubbed
yes it is a larger sway bar, ask if it has collar locks so it stops the sway bar from sliding left and right. I bought my locks at grainger and another set off ebay.
lovely, i just did a 03 and had moog with no issues, i am fixin to do it this spring with a large bar and big brakes all at once on my 04 silver and might just order both style end links cause you mention that. Thank you!
I think ,but did not look, adtr bar might be hollow type.not sure though
Recommend the Addco solid bars for the front and rear.
Sway Bars – Addco
Front – 2196 (1.25” diameter) - Solid
Rear – 650 (1” diameter) – Solid
Greaseable Sway Bar Bushings - Energy Suspensions
Front – 9.5165 or 9.5172
Rear – 9.5161
I believe the Addco bars come with the collars.
NOTE: you will need some modifications to make the rear greaseable bushings to work. Here is a link I posted on the modification.
https://www.mercurymarauder.net/foru...ad.php?t=93480
If you already haven't, upgrade the upper & lower rear control arms and Watts link (I used Metco parts). Once done you'll have a Marauder slot car.
So the Addco's rears don't come with greasable bushings?
Addco bars can be hard to get. They don't run them regularly, some sites like summit, jegs may have, but often drop ship directly and you keep getting delivery dates pushed back. Addco had an issue when they moved to FL a couple years ago.
