Results 1 to 12 of 12
Thread: accufab throttle body
    Dec 2006
    Eagle Pass, TX
    I am trying to obtain an accufab throttle body for the Marauder. I can't find it in any of the parts websites, I did one time before. If any one is looking to sell theirs, PM me with an offer.
    Without Change, There can be no Victory.
    Hawaiian Islands
    Go to the Accufab web site...You'll find it there...
    That's were I got mine...I believe it's listed under Mach 1...
    ALOHA
    '03 A Build Date 8/02
    F.I.T. #6 ***RESURRECTED***
    *444 RWHP / 401 RWTQ
    *10 lbs. Boost
    *P1SC1 ProCharger
    Aug 2005
    Macclenny, Florida
    Quote Originally Posted by Local Boy View Post
    ALOHA
    Randy, did you have any throttle sticking problems?
    I can't get mine to work smoothly, so I haven't installed it yet.
    ~Jim
    2004 Mercury Marauder SB
    Apr 2005
    The Pitt, PA
    Quote Originally Posted by jimlam56 View Post
    Jim, I know you've said that about a hundred times, but I just can't see why. Have you called accufab? Seems to me they'd stand behind the product or at least offer a reason why and a correction.
    Mine was perfect day one (about the same time as you in the GB) and has been installed, TB spacer added, TB spacer removed, upper intake changed, etc, basically on and off the car repatedly over the 50 or so thousand miles I've had it. I cleaned it once and regreased with lithium just cuz I had time and felt like it. I gave away my stocker, I'm so confident with it!
    Bro, I just hate to see your hard earned $ collecting dust!
    Call Accufab or give me a call. Maybe I can help?
    2013 Ford Taurus SHO
    #1649
    boi
    Jim, I got mine with the last GB and it's worked flawlessly since. I'd call Accufab.
    Now if I can just get a oval TB instead of the twin bore......
    My Accufab TB was also sticking when I first installed it...it would hang up 1/3 open when you got off the throttle and the engine would just keep revving.
    I carefully & sparingly sprayed all the pivot points and shafts with teflon based lube and it has worked great ever since.
    Hawaiian Islands
    What your problem may be is the cruise control cable...
    My CC cable was about an 1/8th too short, because it's mounting point on the TB was a little more forward than the stock TB...causing the throttle to not close completely...
    I just modified the cable bracket ( on the manifold) to move the CC cable a little forward...Problem solved...
    Good Luck...
    ALOHA
    *10 lbs. Boost
    *P1SC1 ProCharger
    Wisconsin
    americanmuscle.com has the TB for a good price!
    #1724 of 3214 Built 02/13/2004
    2004 Marauder black/moonroof
    SCT flip chip, 4:10's, lowered, big brake kit
    Kenwood KDC-X790 & 4 Kenwood speakers, 10" Sub
    Addco tube sway bars & performance shocks, Metco's
    Zex dry nitrous kit, Full SW Exhaust Kit, PI 3000 Stall
    5.0L Stroker assembly, Self installed!
    E.T. on drag radial tires: 12.270 @ 111.16 & 1.66 60'
    One off custom Hood all steel too.
    SOON TO BE Vortech supercharged
    Ryan Schmuki
    2003 Marauder, black with 4.10s n tune (sold)
    1968 Fairlane 347 built stroker(fast)
    1963 Galaxie 390 auto
    2010 Mercury Milan
    2019 Taurus Limited
    Feb 2005
    Jacksonville Florida
    Quote Originally Posted by fairlane347 View Post
    Their price is pretty good.
    It's only about $30+ more than my group buy price which is darn good. And they say they have 12 available.
    I also sent him a pm and gave him contact info on the place I did the group buys through. Never got a response so dont know if he checked it out.
    2003 MARAUDER ---SOLD---
    -MOD LIST-
    Ø MMR Race 1100 shortblock, Polydyn coated pistons
    Ø Pro Turbo Systems turbo kit with Precision 76GTS turbo with polished H compressor housing
    Ø Ford GT Complete Cylinder Heads (Cams, Springs, Retainers, etc)
    Ø Twin Ford GT fuel pumps, -8 braided stainless lines and billet rails
    Ø Custom All Metal Cowl Induction Hood
    Feb 2005
    I talked with the guy who I did the group buy through the first 2 times.
    He has 5 of the twin bore throttle bodies for our cars left. He will honor the group buy price we had before. It was $319.
    If you are interested, just pm me and I will get you in touch with them.
    -MOD LIST-
    May 2007
    Nixa, Missouri
    What's the benefit of the Accufab throttle body? More hp/tq? Better throttle response? Just curious.
    Lidio Tune - Ford Racing 4.10 Gears - JLT CAI
    Apr 2005
    The Pitt, PA
    Quote Originally Posted by Professor View Post
    Throttle response and bling. Tiny bit of HP/TQ, but not appreciable. Does breathe easier and give better off idle response esp when blown.
    #1649
    boi
  1. Problem with my Accufab Throttle Body sticking
    By BlkRauderMatt in forum Shop Talk
    Last Post: 03-12-2008, 05:06 AM
  2. Accufab Single Blade Throttle Body Part#?
    By BruteForce in forum Shop Talk
    Last Post: 02-10-2007, 01:25 AM
  3. What would you think if this throttle body fit the marauders?
    By 2003CTMarauder in forum Community Discussion
    Last Post: 03-04-2006, 01:10 PM
  4. Wanted, accufab throttle body
    By txmarauder in forum Community Discussion
    Last Post: 10-23-2005, 08:28 AM
  5. Accufab Throttle Body Installed and WOW!
    By JET in forum Alternative Automotive
    Last Post: 04-18-2005, 08:41 AM
