Results 1 to 14 of 14
Thread: Another tip from the master
    Apr 2003
    Rock N' Roll Hell
    Exclamation Another tip from the master
    For those of you with centrifical superchargers you might run into a problem sometimes. That problem being that the tubing will blow off can cause your car to stall. A few months ago I mentioned to check the clamps often to make sure they were tight.
    Recently I discovered it's much more effective to tighten them with a wrench as suppose to a screwdriver. The screwdriver is good to get the clamp going if you need your other hand to hold the tube, but when you want it tight as possible, use a wrench. My blow off problems have now vanished.
    Also when you tighten the piece that attaches to the throttle body, make sure you are tighening it in the center of the oval. The corner may look better, but it won't seal as well if you tighten it from the side.
    I hope this helped some of you, but chances are you all already know basics like what tools to use for what jobs.
    "Bye Bye, Johnny B. Goode."
    Nov 2009
    Oakbrook, il
    so are u still running rich?
    A legend quote a True Ride can not be no Rider without a Marauder
    Finally Eatonized by ZackZillaaaaaaaaaaa!
    Cardomain link: http://www.CarDomain.com/ride/3380944
    A bank is a place that will lend you money if you can prove that you don't need it
    Apr 2003
    Rock N' Roll Hell
    Quote Originally Posted by bawazir View Post
    Yup. Haven't dyno tuned it yet.
    Nov 2009
    Oakbrook, il
    When are you going?
    Jun 2009
    Abilene, Texas
    You just now figured that out?......
    2003 Marauder - Ebony
    2006 CVPI P71 - Ivory
    Direct Vent Injection
    You're so far back in the closet you can see what's going on in Narnia.
    Thanks for the tip, been doing that for the last 30 years.
    It actually did blow off on me once, now I keep a 1/4 ratchet setup in my console just in case.
    18psi pulley
    Billet Oil Pump
    ARP Bolts and head studs
    Snow Methanol Injection
    3500 Stall Converter (PI)
    Stryker 340 Fuel Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Jun 2008
    Waukesha, WI
    Hairspray on the rubber connecters helps
    and T-bolt clamps!
    (sorry Dave, I couldn't resist!)
    Taxachusetts
    The all knowing all powerful Zack didn't tell you of this?
    Marauderless....
    Apr 2003
    Rock N' Roll Hell
    If you turn the key all the way, the car should fire up too.
    Aug 2005
    JUPITER
    and a socket is even better then a wrench grasshopper!!!
    2003 300A Black MM
    Ride it like a Ford.!!
    People still use screwdrivers for clamps???
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Jun 2005
    East Lansing, MI
    Stainless T-Bolt clamps. End of problems. I'm not that shocked by this, lots of people still use worm clamps on charge pipes, and use a screwdriver to tighten them.
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    Taxachusetts
    Marauderless....
  1. Master Window Switch
    By 5arnold in forum Community Discussion
    Last Post: 08-11-2008, 08:15 PM
  2. master cylinder
    By eric jones in forum Shop Talk
    Last Post: 09-06-2007, 02:35 PM
  3. Master cylinder and pump
    By Lowndex in forum Shop Talk
    Last Post: 02-18-2007, 12:02 PM
  4. A query for the Master
    By SlkMerc in forum Reinhart Automotive
    Last Post: 11-24-2006, 01:23 PM
  5. Flow Master Help!
    By Patrick in forum Community Discussion
    Last Post: 09-29-2003, 05:07 PM
