Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
Thread: Engine warm-up time
    Aug 2003
    Caledon East, Ontario
    Engine warm-up time
    OK, this is a pretty feeble question, technically speaking. Yet it's something I've always wondered about.
    Back in the days of carbureted engines, you had to let a car warm up for a while or they would stall on you (especially if you were driving an older/poorly tuned car). The problem was magnified in cold temperatures. Now with the wonders of fuel injection the quirks of carbs are gone, and so is that specific reason for warm-ups. BUT there's that thing I've always heard about start-up being the toughest time for engine wear, letting the oil circulate properly, etc.
    So- is it possible to offer any kind of general statement about how much time should pass between the engine starting to run and when it is OK to put it in gear? This question nags me more during cold snaps like the one we're having now where it is going down to as low as -20°F. Sometimes I hear creaks and groans from the car when it's this cold that make me feel 'sorry' for it!
    What about hard acceleration with a cold engine?
    Would advice for the MM be applicable to most recent makes/models of cars and light trucks, and would or should the time increase as the temp drops?
    I've read that it's less wear-inducing to get your car going at normal road speeds and normal work load as quickly as possible. Letting the car idle in the driveway to "warm up" is said to actually be worse for the engine. I suspect that this is why our engines tend to roar upon start. It's probably programmed this way on puprose to get the engine up to operating temperature quickly.
    2003 Mercury Marauder
    2007 Lincoln Town Car
    1993 Crown Victoria LX
    Dec 2003
    St. Louis, MO
    I agree with Fourth Horseman, I was taught to start the engine, wait about 5 seconds and then drive mormally, but I usually wait until the engine has warmed up before any hard acceleration.
    "Let's Roll", Todd Beamer, UA Flt 93, 09/11/2001. Never Forget!
    Nov 2003
    Powder Springs, GA
    Depending on how cold your motor is on start up let it idle 30 sec to one minute to ensure the oil is circulating then get it moving. No WOT acceleration until up to normal temp plus a few minutes to get the oil up to normal temp. Water temp will come up fairly quickly but oil temp will lag behind as it has the crank and block to warm up. This is just one persons assesment with lots of experiance
    Barry Reade
    03 300B, MMDS, 4:10, Stud Girdle, Metco cont. Arms, Addco Bars Fr & Rr, Real Oil Press. Gauge, DR Stage II Trans, Deep Pan, BIG Tranny Cooler, real Trans Temp gauge, DR Tune, Densos, 180F thermostat, Rr Cyl Cooling mod, Undersrive Pulleys, PI 3K TC, Gods Head Badges Grill, Trunk, Steering wheel, Kooks Hdrs (Jet Coated) with Hi Flow Cats, X pipe and magnaflow Muffs, K&N Cold air Kit, Pro Guard, BFG KDW2
    Wanted:
    Trilogy Facia/Ground Effects Pkg.
    Off-Shore America
    Me three agree. Start it and go. The program that revs the engine at start up will not allow much other than normal crusing until the engine reaches normal operating temp. Last winter, I timed it on zero and below zero days. 7 minutes of normal driving until the engine reached 180 degrees, and I started to get heat in the cabin. BTW, I understand the early morning groans, but letting the car warm un in the drive way won't do much for that. If you let it idle until the cabin is nice and toasty, you're actually doing more harm than good, and the MPG really sucks.
    May 2003
    Edmonton, Alberta
    I can't say for the Marauder, but I let my CV idle 10 - 15 minutes in neutral if the weather is below -20C.
    I find the motor hasn't come up to temp yet, but the oil is flowing and the tranny fluid has built up a little heat, making for smoother operation. Also helps clear the morning ice off the windows - less scraping. Just my $.02.
    IIRC, someone here blew a motor when the just started her and went WOT, 5000rpm without sufficient oil flow. Our manual does reccomend not idleing to warm up.
    2003 Marauder 300eh - Stock
    Born: 12/03/2002
    Adopted 02/17/2003
    Trilogy #243
    AVIC D3
    SS Inserts.
    Metco Control arms and Watts link.
    QA1 8 way adjustable shocks and struts.
    Addco front and rear anti-roll bars.
    Wilwood front brakes.
    I can't drive 55. I'm looking forward to not being able to drive 75 ether.
    Mar 2003
    Watauga ,Texas
    Thumbs up WARM is good
    Well when it gets that cold I always had a block heater and in line water heater plug 'em both in for a half hour or so before initial start up. Having spent time in Montana and Alaska this seemed to work best.
    However WOT before complete engine warm up WILL kill engines. Esp in extreme cold.
    JMHO
    Joe Clancy
    Lawrence Twp., NJ
    I have always waited 3-5 minutes before driving away at any time of the year.
    It is best to keep vehicle below 35 MPH till engine is warmed up.
    Back in the 60's & 70's I use to change plugs often because of somethimg called a high-speed glaze forming on the plugs.
    I would start up and just go!!!!!
    Times change
    Like I said I always let them sit for a "few" minutes.
    When it is cold, if you watch the tack the RMP's will drop after a few minutes. Then go
    Member # 383.
    2003 Marauder Black.
    Build 8/13/02
    Launched 9/28/02
    Sold May 16, 2018
    #3,646 of 7,839 black '03
    Long Island, NY
    Start and Go
    IMO it is disiraible to start and go. The engine will come up to operating temperature faster while your vehicle is moving. Drive moderately untill engine warms up. No WOT.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Aug 2003
    Many thanks for all your replies. This shows again why I'm addicted to MM.net, because you can talk to friendly people about anything
    Mark McQuaide Guest
    My last car, a Passat V6, had a 30-valve motor. The owner's manual specifically said not to warm it up at idle because it extends the cold running time, which is when you get the most wear.
    Also to consider is emissions, they want you to warm up the car quick since they release most of the emissions when cold.
    Like most of the people who responded, I start it and go, and drive gently until it's warmed up.
    Aug 2003
    Affordable Detroit
    Or just do like I do and let it sit in the garage until April.
    Dan
    Orlando, FL
    Warm it up to suit your own body temp, I hate freezing behind the wheel.
    Charlotte, N.C.
    [QUOTE= Also helps clear the morning ice off the windows - less scraping. Just my $.02.
    [/QUOTE]
    Well, I recommend what I do --I place cardboard over the windshield and held down by the wipers stopped in "mid-operation"---works everytime--no scrapping here...and as for the warm up time period--it's best summed up by saying to gently throttle till normal operation temp has been reached...which is about 7 minutes per Mac......I'd say thats about as good as your gonna get for that answer.............This place
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    Alt .SSHS 9 --11/7/09
    '06 CV P71 Street Pkg
    Interior Marauder Floor Shift
    All New Parts
    In Memoriam....11-14-13
    Nov 2003
    Cincinnati, OH USA
    Post
    I usually start up the car, and let it idle at least 30 seconds, to a minute at most before I start going. I figure it's best to give it a little time for the oil to work it's way around before starting to move. From there, I use nothing but light throttle and keep the revs below 2500rpms until the engine has reached full operating temperature.
    2006 Silverstone AWD Chevy Trailblazer SS
    -custom grind cam, kooks long tube headers, pcmformless tranny cooler, Vector CAI, Vector custom tune, Corsa catback, efans
    2004 Silver Birch Mercury Marauder
    -gone
  1. Transmission Options
    By jabird56 in forum Community Discussion
    Last Post: 12-05-2005, 05:50 PM
  2. '04 DTR Marauder w/ blown engine! (I don't mean supercharged)
    By tta197 in forum Community Discussion
    Last Post: 08-11-2004, 08:49 AM
  3. The Prowess of the V8 Engine:
    Last Post: 01-15-2004, 03:41 PM
  4. 4.6L 3V VVT Engine
    Last Post: 05-20-2003, 11:27 AM
  5. What is the stall on the Torque Converter?
    By cyled in forum Shop Talk
    Last Post: 02-04-2003, 06:32 PM
