Results 1 to 15 of 23
Thread: Transmission shudder
    Jul 2005
    Land of 10,000 Lakes
    Yikes! I hit 36,000 trouble free miles last week. Today I felt a shudder from my transmission. I was pulling away from a stop sign, in drive, and it felt like the tranny didn't know for certain wether or not it was in drive or reverse.
    No extended warranty (I reminded the salesman I was buying a Mercury, not a Hyundai). He didn't want to argue that point.
    No factory warranty.
    What do I do now? It hasn't happened since. Anything I should check? Thanks.
    "No one is useless if they can still be used as a bad example." ~ SSgt. Miller.
    "Loud pipes lose rights."
    Oct 2003
    Beaufort, SC
    Flush fluid first...If that ain't it you will have to go inside??
    I have a cure for converter shudder but this doesn't sound like the converter.
    Good Luck!
    Marauderjack
    Rockford
    Here is to a trans service taking care of it!
    Every 15K, cause she earned it!
    If your transmission fluid hasn't been changed in 36,000 miles, it's overdue.
    Solution 1): At the very least, do a pan-drop and filter change...since that only changes approx 4 quarts of ATF, it may take a few miles of driving to notice any difference. Do another pan-drop (no filter this time) after a few hundred miles, then another one again. After that, get on a regular schedule of pan drops every 15,000 miles, with a new filter every other time. Installing a transmission pan with a built-in drain plug will make the job easier and MUCH less messy.
    Solution 2): Do a complete flush...that will change 95% or more of the ATF and the improvement in shifting should be noticeable immediately. Do a complete flush every 30,000.
    Off-Shore America
    This is good advice, and change the filter too. Your shudder may be just tired ATF, or, there could be other problems to diagnose. However, you cannot correctly diagnose that without ruling out old fluid. BTW, make sure the new fluid is pyre Mercon V, not another type with additives. Keep us posted?
    BTW, make sure the new fluid is pure Mercon V, not another type with additives.
    ^^^what Mac said^^^
    Nov 2003
    Horntown, VA
    I used the Cam II type V semi synthetic when I changed last. Gone 12k miles and shifting very nice! Also installed a drain plug in the factory pan so the next change will be less of a mess.
    Plate - "EVILMERC"
    Aug 2003
    Central Iowa
    Do most of the F/L/M dealerships use a pure Mercon V? Just curious as I am taking the car in for an oil change, tranny service, and rear diff. service. I already verified that they use either Ford or Castrol synthetic for the oil, but did not ask about the tranny fluid.
    Eric
    2004 Silver Birch Marauder - Sold 04/17/09:
    - #2703 of 3213 '04 Marauders
    - #852 of 987 Silver Birch Marauders
    - Born On Date: 04/23/04
    - Warranty Start Date: 08/11/04
    - MINE as of: 09/09/05
    2003 CVPI - Daily Driver
    - Purchased 05/29/07
    Quote Originally Posted by Eric91Z
    A dealer had BETTER know the difference and use only Mercon V, not plain Mercon with some miracle-in-a-can glop.
    Eric, beware of anyone who claims Castrol is synthetic oil. It is NOT (except for 0W-30 GC- German Castrol). All of their product except GC is Group III mineral oil. Ask the dealer to use only Motorcraft oil in your car, unless you want to bring your own.
    Off-Shore America
    Quote Originally Posted by Krytin
    I don't know the specs of this substitution, but it's seems fine in your application. Bravo!
    Is it cheaper?
    Do you have an aftermarket torque converter?
    Do you have a tranny retune over OEM specs?
    Now that you have a drain plug, you save even more money in maintenence. Just drain the pan every 5-6K miles and refill. Should save you a lot of money over the long run.
    Western Chicago 'Burbs
    [QUOTE=Leadfoot281]Yikes! I hit 36,000 trouble free miles last week. Today I felt a shudder from my transmission. I was pulling away from a stop sign, in drive, and it felt like the tranny didn't know for certain wether or not it was in drive or reverse.
    The advise here is good. This isn't just a MM problem but seems to be common with Mercurys. I had a 96 Cougar and had the same problem at 40K.
    A trans fluis change fixed it.
    Black 2004 Marauder
    Has everything but a moonroof
    35% tint all the way around
    Born on 04/15/2004
    Adopted 04/30/2004
    Number 2491 of 3213 Made in 2004
    Jul 2005
    I had the 30k mile service done earlier this year. Fuel filter, oil change, alignment, and trans service. The rest I done myself. Brake inspection? Give me a break! Ditto for air filter. The tires were almost shot so I got new KDWS at 35k.
    At any rate, My dealer messed up the fuel filter install. Check engine light came on. They re-set the trouble light and told me it was "possibly air" in the fuel line, and to bring it back if it gave me any more trouble.(it didn't). The 30k "tune-up" took 8 hours!
    I don't have any idea what type of fluid they used. I'm certain they didn't drop the pan. I'll get that done soon.
    With all the trouble Ford Automatic's have given me over the years it's a wonder I bought another one. Why doesn't Ford just give up and start installing GM transmissions in their cars? I'd rather have a TH350, TH400, or TH700R4 in my car. Bring back the Top Loader! I'd even prefer an old 727 torqe-flite to the junk were saddled with. Ford even spelled AOD backwards!
    Sorry 'bout the rant..... And thanks for the advice. I will keep you posted.
    Lake Charm, Fla.
    New tranny fluid
    New tranny fluid should solve your problem.....
    they probably gave you only a partial flush at your last service.
    Good Luck!
    "Best of Show"
    MARAUDERVILLE IV
    ORLANDO, FL
    11/11/06
    Member #1031
    Conceived 2/25/03
    Born 3/21/03.. "7002 of 7838"
    METCO DS/Loop
    and still kickin' ass!
    Quote Originally Posted by Leadfoot281
    Actually, they most likely DIDN'T mess up anything. It's common for the CEL to come on after changing to the larger fuel filter (FG-800A), so as long as it didn't come back, I wouldn't worry about it.
    I have had three CV/GM/MM cars since 1997. all have had tranny shudder at one point or another. a full flush is in order. Whenever any of mine show this symptom a full flush corrected it within about 100 miles of the flush.
    The MM had it at 17K miles. a full flush fixed it. I'm at 35K now and it's probably due again.
  1. Transmission Fluid Exchange.
    Last Post: 05-31-2005, 12:18 PM
  2. Transmission and Fluid Change Question
    Last Post: 03-29-2005, 05:32 PM
  3. Help! 2nd Transmission Gone
    By John F. Russo in forum Community Discussion
    Last Post: 11-05-2004, 01:02 PM
  4. Cobra Transmission:
    Last Post: 08-29-2004, 09:22 PM
  5. Transmission Problem Fixed
    By merc in forum Community Discussion
    Last Post: 07-26-2004, 11:31 PM
