Results 1 to 13 of 13
Thread: sct tuner
    sct tuner
    anybody here use them ,and how do you like it
    St. Paul, MN
    I have the Pro Racer package, and love it. You have total control over the powertrain. It works extremely well.
    2004 Marauder--DTR
    Infinity Kappa 572.5 speakers all four corners
    Wheel widening by Lidio
    Nitto 305's
    Metco control arms and Watt's link
    2004 Trek 5200 Project one--as black as possible--lots lighter than the MM, but powered by a lot less HP
    1960 Austin Healey 3000 BT7
    VNMUS Guest
    Was thinking about picking up the Xcal-2.
    May 2006
    Minneapolis Area
    i have an Xcal2.. i love it. you can use the extreme tune software to adjust things beyond what the xcal2 can do on the device itself.
    03 300A, Tint, FPN Tune
    Lower Grill Mod
    Flowmasters
    Delete Tips
    B&M deep pan
    BC4E Dead Pedal
    Larger than stock black Bullitts
    Rockford
    I had the 9100 with an N/A tune calibrated for 4:10's.
    I sent it to Lidio for some refining and now I am using thier single bank chip that came with the Trilogy kit.
    Both products though I like the tuner better, perform well in all conditions.
    The contacts on the circuit board have a resin coating that has to be removed so the chip can make contact.
    On My Trilogy install , that was the only issue I had.
    I had not cleaned the (edge of the circut board)terminals well enough to make a good contact.
    The first turn key nothing happened, called Chuck and Claude, figured out what to check.Tried recleaning the terminals, and bingo!
    The car started and ran fine, It just set a check engine light on.
    I guess three tries cleaning the resin off the board was the charmer, finally was able to remove the cel.
    Pros and cons: acess to the chip is a little more difficult than a hand held
    The loading time was a bit longer with the hand held tuners.
    The ex-cals'
    more recent versions load much faster than the 9100, I used before.
    Dec 2004
    Orlando, FL area
    Xcalibrator2 from Dennis Reinhart is what I use. Came with 93 octane performance tune and performance tune for 4.10 gears already loaded from DR. Easy to use, easy to return to stock tune if necessary. Lidio also has an excellent rep.
    White Lightning Kiarauder:
    Black Thunder:
    Sequence number is 39 of 3213
    Traded in 12/12/10
    XCalibrator2/Reinhart tune
    Sequence number is 37 of 327
    Martyo's Garage!!!!!
    Feb 2006
    Rosemount, MN
    SCT XCal-2 from Reinhart.
    McDonough, GA
    Thumbs up 9100 for Sale
    I have a SCT 9100 tuner for sale with PC link cable and transformer - new condition with box. Tuned for N/A and 4:10s.
    Glenn
    Trilogy #124 SOLD - 8/2014
    11.80 @ 117.16 MPH: SSHS9
    1.74 sec - 60'
    443 RWHP/437 RWTQ
    "Stock Internal Engine" - Click Below
    Jan 2006
    Central Ohio
    I have an XCAL2. I got it with my SuperCharger from DR. It is set up for 3.55's, 4.10's, Valet Mode, Race Gas and Bad Gas.
    Before I had the XCAL2, I had a SCT Chip from Lidio. I sold it when I got the XCAL2 due to the ease of updating Tunes.
    KillJoy
    If you have an 04' and you want to save a few bucks, here is an SCT XCAL2 with a Lidio tune, 3 weeks new.
    http://cgi.ebay.com/ebaymotors/ws/eB...0317627&rd=1,1
    04' DTR Loving every minute
    VNMUS Guest
    Quote Originally Posted by Bill Lalk View Post
    Thanks for the info. I may pick it up.
    VNMUS Guest
    According to the seller, the tune is only good for the 04 and I have an 03. Is this accurate?
    Quote Originally Posted by VNMUS View Post
    Yes, you would need to change the tune to your computor, one of 2 different tunes. The 04' has a third and different computor. But, you can replace the tune with the correct one.
  1. SCT Tuner Software
    Last Post: 10-26-2004, 05:00 AM
  2. SCT Tuner is here, now what
    By wesman in forum Shop Talk
    Last Post: 10-06-2004, 02:33 PM
  3. Safe RPM for rev limiter???
    Last Post: 07-04-2004, 10:41 AM
