That is the best way I could put it, but I installed my intake spacer last night, by the way...it works, well...but my question is the inside of my intake, how in the heck do I clean it up, and better yet why is it all there?
Welcome to the DARKSIDE...
2003 Black Mercury Marauder
Black and Chrome RPM 505 wheels staggered 18x8 and 18x9, Custom tune by ELD Performance, JLT cold air intake, FRPP 4:10 gears, PI 3000 Stall Torque converter, PHP intake spacer, Stainless Works Complete Exhaust, Eibach Pro Springs, Steeda underdrive pulleys, Custom Painted Black factory spoiler, 15% Tint front and rear , Kenwood Excelon 6x8 Front and 6x9 rear Speakers, Pioneer 600w 4 channel amp, Zack and Mack Control arms, Addco Front and Rear Sway bars
Best run: 13.75 @ 99.6 sec on 4 May 07
You can get a can of spray stuff from Ford that cleans it up. Just start the engine, then squirt the stuff in the motor's pie hole, and it's all fixed.
Mike,
As always, you have the best way with words, by Pie Hole...you mean the throttle body...I figured as much, but where is the crud coming from.
Its okay to spray the throttle body cleaner into the intake? I noticed my intake was filthy the last time i cleaned my T/B but was afraid to spray inside the intake.
Reinhart tune, NGK TR6 Plugs, 180 Degree stat,EMP/ Stewart Water Pump, K&N Aircharger, Cobra Exhaust, Megs Delete Tips, Flowmaster 40 Series Delta Flows, 4.10 gears, COP Connectors, Underdrive Pulleys, PHP Intake Spacer, 255/55/18 KDW2 Rears, Powerslot Rotors, Hawk Pads, TCI Deep Trans Pan, Ford Racing Girdle
^^^what RR|Suki said^^^
If you are talking about a "golden brown" tint, then it's normal. There's no need for cleaning as it doesn't affect operation and will just re-appear shortly anyway.
If you've got sludge build-up, then that's a different story...
"Pie Hole"...way to go, Mike...
Sludge build up is what it looks like..on the passender side of the intake.
It will be more evident on the passenger side as that's where the PCV vacuum comes from. If it's just a light film, then it's not a problem, but if you've got it so thick that you can scrape it off with your fingernail, I'd call that excessive blow-by. How many miles on your car?
When you install the Trilogy in you will not have to worry about BS cleaning. My intake is setting in the parts bin.
Merc's Garage
its normal to have build up in the intake so nothing to worry about
Rolled over 74K and she still pulls like a freight train...and Merc...I am coming....I am coming....
Merc's Garage
normal carbon build up, you should have seen this 96 cavilier couldnt even tell thier was metal under it, holy cow
Mine has a little buildup at the EGR ports but the PCV area is clean. But I do have an oil trap on the PCV line, so I suppose it's working.
I had to re-arange the PCV lines on our SVT because it was literally sucking up so much oil the car would stink and blow smoke. Even with a new valve. The MM hasn't done this yet.
You can blast carb cleaner on it but it'll just sink to the lowest point of the runner and gunk up there. The correct way is to remove the intake and blast it all out with cleaner and compressed air.
Matt H.
(sold)2004' SB, 268rwhp/295tq
2017 F-150, 5.0
2013 SHO DIB Performance Pack
