Results 1 to 4 of 4
Thread: Engine Oil Temperature
    Somebody out there's got an oil temperature gauge, what temperature does it normally run?
    McDonough, GA
    Oil Temp ---
    180-190 degrees even during high 90 weather at 70-75. I believe part of it is due to my two Trans coolers that really cool the trans and perhaps help also with the engine? I also have the 180 thermostat.
    Glenn
    Trilogy #124 SOLD - 8/2014
    11.80 @ 117.16 MPH: SSHS9
    1.74 sec - 60'
    443 RWHP/437 RWTQ
    "Stock Internal Engine" - Click Below
    Oct 2008
    Toronto, ON
    A bit further north, I see 200ºF when ambient is above 20ºC (is that about 75ºF?), as high as 220ºF after a bit of spirited driving (but it quickly goes back to 200ºF). Below about 15ºC, it takes a while to reach 180ºF.
    Oct 2003
    Beaufort, SC
    Mine has been as high as 220* but normally runs between 180* and 190*.....usually a few degrees below the coolant temp!!
  1. Oil Temperature Observations......
    Last Post: 03-13-2008, 05:13 AM
  2. Engine Bay Temperature
    By Pat in forum Community Discussion
    Last Post: 09-12-2006, 01:38 PM
  3. Outside Air Temperature Sensor
    Last Post: 11-07-2005, 02:13 PM
  4. Highest Temperature ???
    By MENINBLK in forum Shop Talk
    Last Post: 07-05-2005, 12:53 PM
  5. Oil Temperature
    By schuvwj in forum Shop Talk
    Last Post: 01-19-2004, 05:34 PM
