At the Junk yard to get a caliper bracket or cradle or whatever u may call it. My question is what range of years will have the same one as us? And I assume it's all TC, GM, and CV within that range, right?
03+ knuckle, caliper and bracket, wheel bearing and hub, brake hoses, rotors, ect are all the same. Later (like 07ish and newer) switched from aluminum LCA's and cast iron UCA's to stamped steel LCA's and UCA's but they are still bolt on compatibility.
02- nothing is compatible from the front suspension.
