I was driving My 04 Black on Saturday, went to pick up some friends to go apple picking. She said "your car smells hot" mind you it was 60 degrees outside and the car ran fine all summer with the AC etc... Yeah no problem...
3 min later waiting at Starbucks idling, my eye catches the temp gauge at 3/4 position!!! Yikes. So we headed home to swap out to the 04 Vic LX, the temp went down once moving.
When I got home later that afternoon, noticed no obvious coolant leaks, some crud along the COT plug I opened the COT plug and coolant came right out and a burp. Ran it for a while with the funnel in place, no real bubbles came out, and really did not add any net coolant. Drove around and of course could not budge the temp gauge past half.
Next AM, pulled the COT plug and put in the tiny amount which went down, tried to burp again and just filled the funnel up with expansion. This time I noticed the O ring on the COT plug was falling apart!! HMM
Turns out I must have had more of a air leak instead of a coolant leak, so it formed a bubble in the COT.
I tried to search for info and came up empty, then used google Site:www.mercurymarauder.net Crossover and found this
http://www.mercurymarauder.net/forum...63&postcount=9Originally Posted by vegasmarauder
So I am driving the LX till I get a new O ring from Mc Master Carr
The size has the -015 designation
Chemical-Resistant Viton® Fluoroelastomer—Offering the same excellent chemical resistance as multipurpose Viton® fluoroelastomer O-rings, except with a durometer of A90 (hard) for better wear resistance. These resist boric acid, citric acid, isopropyl alcohol, fuels, and transmission fluids. They meet ASTM D2000/SAE J200. Temp. range is -20° to 400° F. Color is black.
Fractional
Size Actua Inch Size Pkg Qty. Pkg.
Width: 1/16 Fractional (0.070" Actual)
DashNo. ID OD ID OD
015 9/16 11/16 0.551" 0.691" 50
8297T125 $11.25
Product Detail
Abrasion-Resistant O-Ring, Chemical-Resistant Viton®, Dash Number 015
Packs of 50
ADD TO ORDER
In stock
