Results 1 to 4 of 4
Thread: Fuse
    Euless, tx
    Fuse
    Hey guys I have a question what can cause the 30 amp fuse to pop under the hood when I kick on the ac the steering pump stops working (steering wheel gets really stiff) and my speedometer stops working? Thank you guys in advance.
    First i would swap the ac compressor relay and see if the issue is resolved, it may be a wet or bad relay for that circuit.
    power wire short to ground is what causes fuses to blow.
    I would unplug one connector at the compressor, then turn on the ac and see if it still blows the fuse or not. If it did blow the fuse, i would look at the wires and check short to ground, check wire to ground connectivity.
    If the wire is connected to ground, check the book and see if it is a ground wire or a power wire. If its a power wire, and its grouned, then there is the issue.
    I can only assume that the ac compressor has more than one wire connector on it, you might have to try the other connectors.
    I dont think the clutch is bad in the ac causing this issue, i wonder if you can ohm out the electric clutch on the ac compressor and see if it is fubar. I really dont know, its a start. Start with the relay first.
    Euless, tx
    Will try that dont know too much about cars but you explained it pretty good sir..
    Euless, tx
    Swapped out the air bag compressor and that did it man I'm guessing the compressor was going bad and a short somewhere
  1. Fuse Box
    By Lowndex in forum Shop Talk
    Last Post: 01-07-2018, 11:59 AM
  2. Wanted To Buy Fuse box
    By fastblackmerc in forum Marauder Parts/Misc. Wanted
    Last Post: 06-01-2016, 12:01 PM
  3. Wanted To Buy Fuse box for 03a
    By MAROGER in forum Marauder Parts/Misc. Wanted
    Last Post: 11-16-2015, 07:52 PM
  4. Need fuse help
    By slickster in forum Community Discussion
    Last Post: 03-21-2012, 03:16 PM
  5. Fuse Box
    By walela1 in forum Shop Talk
    Last Post: 01-21-2007, 08:58 PM
