Results 1 to 15 of 15
Thread: How can i run a wire from the Engine bay to the inside of my car
    NEW YORK (LI)
    I want to run a wire from the Engine bay
    to the inside of the car. Is there any pre made holes in the fire wall.
    If so where would it be located. ??
    I figured I ask before I went tearing up the carpet looking for one.
    Some Good advice from Experience With my P71 Don’t sleep and drive the concrete medians don’t move!!
    2003-A Mercury Marauder BLACK
    70K
    X-cal 3 Tune by Dennis Reinhart.
    KOOKS Complete Long Tube Headers , X Pipe , Spin Tech Mufflers.
    JLT Intake.
    Dynotech Driveshaft.
    Aero Force Gauges.
    Pro Guard.
    30% Tint all the way around.
    ZAINO and Collinite (Only The Best).
    Trunk Organizer.
    Hard mounted Garmin - nüvi 750 GPS.
    Hard Mounted SIRIUS Sataliet radio (Sporster 5).
    2 - 10inch Custom Installed JL Audio Subs
    Pioneer DEH-P710BT Premier Deck
    Comming Soon ::
    Precision Industries Torque Converter. (3000 stalll)
    4.10 Gears.
    Brake Upgrade .
    Spoiler.
    Oct 2008
    Toronto, ON
    Instead of looking from the inside of the car, inspect the firewall from the engine side, from under the hood.
    There ought to be at least one 2" or so round grommet on the passenger side, somewhere around the blower motor. On the drivers side, there might be a big rectangular one, about 2" X 4" maybe.
    That's what my '94 MGM had - the MM might be different.
    There is a grommet above the gas pedal and near the passenger side kick panel.
    Port Charlotte, FL
    You should see where my battery cable runs!!!
    Here it is!!!
    http://www.motorcitymarauders.com/fo...***.php?t=1456
    04 Crown Victoria Sport
    1995 F150 4x2 4.9 5spd
    Oct 2005
    Southwest Florida, Lee County
    If all else fails - go to a reputable stereo shop and have the proper size hole drilled and grommeted. It may cost you a $10 tip.
    2004 Mercury Marauder
    2,187 of 3,214
    997 in Silver Birch
    448 with light flint interior
    304 with heated seats
    336 with sunroof
    NEW YORK (LI)
    THANKS ZACK... I found it like you said right above the gas pedal...!!
    70K
    JLT Intake.
    Aero Force Gauges.
    Pro Guard.
    Trunk Organizer.
    Comming Soon ::
    4.10 Gears.
    Brake Upgrade .
    Spoiler.
    NEW YORK (LI)
    Quote Originally Posted by O's Fan Rich View Post
    Here it is!!!
    Thankss O's Fan Rich picks help alot with runnig some wires.
    70K
    JLT Intake.
    Aero Force Gauges.
    Pro Guard.
    Trunk Organizer.
    Comming Soon ::
    4.10 Gears.
    Brake Upgrade .
    Spoiler.
    Jul 2008
    North Georgia
    If you look on passenger side floor board. you will have to pull back carpet to see firewall. there is a rubber seal with a wire coming through it. I drilled a small whole n the rubber and used a coat hanger to push a wire through. it did not mess up rubber seal at all. push wire through starting from the inside. it will bring you beside engine right up to battery.
    Make sure you fuse that wire at the battery end, otherwise it will become a big match stick if it ever shorts.. Just a heads up..
    NEW YORK (LI)
    Thanks guys all great info.!!
    70K
    JLT Intake.
    Aero Force Gauges.
    Pro Guard.
    Trunk Organizer.
    Comming Soon ::
    4.10 Gears.
    Brake Upgrade .
    Spoiler.
    Apr 2005
    The Pitt, PA
    Just run it through the door jamb, around the hinge and tuck it under the weather stripping. It'll be fine!
    2013 Ford Taurus SHO
    #1649
    boi
    Thats what i said!
    3.73's w/400#eaton posi,
    Fresh PCM tune,
    Kumho ecsta ASX's 285/40-255/45
    Tri-Y ceramic coated headers with Cat delete-hookup pipes, spintech pro-street catback dumped before rear axel,
    energy suspension front end kit,
    RAISS Intake w/S&B ,
    MSD 8.5 ignition wires,
    external oil cooler
    bilstein shocks
    NEW YORK (LI)
    Yea yea yea Ok billll
    Dont let your head get any bigger than it already is .........
    70K
    JLT Intake.
    Aero Force Gauges.
    Pro Guard.
    Trunk Organizer.
    Comming Soon ::
    4.10 Gears.
    Brake Upgrade .
    Spoiler.
    Sep 2008
    USA
    I like to use the hole for the hood latch release.
    Apr 2005
    The Pitt, PA
    Quote Originally Posted by massacre View Post
    Good way to chaffe the wire....
    #1649
    boi
  1. 03 Crown Vic with 03 Cobra Engine and Marauder Parts Car
    By 1KFTLBS in forum Marauders for Sale
    Last Post: 12-19-2008, 12:35 AM
  2. 10/5/08 Cruz-in the Country Car Show & Poker Run!
    By SOHCman in forum New England Marauders
    Last Post: 10-07-2008, 07:08 AM
  3. Ok guys, how did I do on the new car...?PIC'S!!!!
    By MinnesotaMuscle in forum The Lounge
    Last Post: 08-17-2007, 09:02 AM
  4. 5w30 vs 5w20... dont throw rocks!!!
    By kj31067 in forum Shop Talk
    Last Post: 07-13-2006, 07:47 PM
  5. Forbes.com Review
    By 213Cobra in forum Community Discussion
    Last Post: 11-27-2002, 07:25 PM
