Selling my 86 notch completely converted to a 90 interior, body, ect... Looking to buy another car so this one needs to go. It's white with a gorgeous black interior
Interior
-all black with rear seat delete
-svo steering wheel
-triple gauge pod with temp, and air/fuel, trans temp
-boost gauge in vent
-dual gauge pod on cowl with oil press and fuel pressure
-autometer shift light on dash
-hurst shifter 1/4 stick in factory location
- aftermarket radio
- heat works
- custom mustang headrests
- new black carpet
- must see to appreciate
Body is clean. Car has no rust!! Car could use paint. But overall a clean car
-Has 4" cowl hood
-smoked headlights with hids
-brand new 17" 03 cobra replicas with new front tires and et streets in the rear
-Drivetrain-
-PSR built engine 306 (thousands invested in engine alone)built for boost
-GT-40x heads ported by Busie Perfornance in PA
- comp cams roller rockers
-Sheetmetal upper intake with ported GT-40 lower
- bbk throttle body and egr spacer
-Custom grind blower cam
-Powerdyne BD11a supercharger with 928 custom billet impeller - 13psi - just rebuilt.
- aftermarket maf - blow through
-MAC shorty equal length headers with MAC Pro Dump exhaust
-Digicon Smart Spark Timing computer
- fully built aod. Full manual valve body, 2500 stall, pa valve body with Trans break. Only 1000 miles cost me $3800 also has overdrive which is controlled by a switch great for cruising or long drives
- walbro 255 in tank pump
- fuel management unit and bigger injectors
-rear-
All new brakes and bearings
3.55 gears
Cobra carrier carbon fiber clutches
Converted to disc brakes
-suspension- have thousands invested in suspension alone
- qa1 tubular k member + a arms
-Upr front coilovers
- maximum Motorsport rear track (panhard bar)
- billstein rear coilovers
- maximum motorsports lower control arms
- double adjustable upper control arms
- maximum motorsports full length frame connectors
- car handles amazing
Honestly prob forgetting a few things. I have thousands into this car. You can race it or daily it. It's a fun car to drive. You won't be disappointed. Has tons of power. Car has been in the 10s at the track. Serious buyers only. $7500. Don't waste my time.
Will trade for classic mustang, maverick or anything cool
Call/text 631-513-9770
More pics here
http://longisland.craigslist.org/cto/3782395272.html
