Can you fit a screw remover bit into the hole?
http://www.homedepot.com/p/Vermont-A...9#.UpZ_5ZCA2M8
I've had a set of these Vermont American Screw Extractor bits for years and they work wonders.
If not.....as Whitey said Vice Grips will work with some exterior damage to the plug.
