I can most likely bet the positive wire to alternator melted because you put the wrong amp fuse. If your alternator puts out 220 amps then get a 220 amp fuse. Here’s my Big 3 setup had it for 7 years almost 100k miles no problems.
The Big 3 setup consists of
Positive Battery to Alternator w/ correct fuse
Engine block ground to negative battery
Body chassis ground to negative battery
Here’s my setup which I also have stinger battery terminals (which I highly recommended) and Stinger 0 gauge wires
300A 8-20-02 #3849
Webasto Aftermarket Moonroof
Rear Spoiler
S55 Tail Light Treatment
5% Limo Tints
Fresh Black Paint & PVD Chrome
Stainless Works Headers & Full Cat Mandrel Exhaust System w/Magnaflow 11229 Mufflers, Martyo Tune & Coolant Mod, Steeda UDP, Stewart WP, JLT CAI & Catch Can, J-Mod, UHaul Pan, Rebuild 4R70W, Dynotech 4' 6061, Forced Lube Mod, 31 Ford Spline Axles, 31 Cobra Carrier w/CF Clutchs, Ford Racing 4.10, TA Girdle & Stud Kit, Carfixer Alignment & SPC Camber Bolts, Ridetech HQ Front Coilovers w/ADTR extended bracket & ADTR Rear HQ Shocks, Arnott P2936 A/C & A-2220 Bags, Gorilla Lock, Cooper Zeon RS3-G1 Tires, Metco Control Arms & Watts Link, Addco F/R Sway Bars, SS Brake Lines, AutoMeter Digital Oil & Volt Gauge, Full VLED Interior/Exterior, Alpine ILX-507, PKG-M780 Headrest Monitors, MRP-F300, R-S65C.2 & R-S68 Speakers, HCE-C1100 & KTX-C10LP Camera System, Viper DS4 & DSM550 GPS SmartStart System, Yellow Optima, BIG III & 200 Amps Alt
