Originally Posted by
Bondfreak13
1100hp on 91 octane, with 11lbs of boost. The SOHC 427 is an absolute beast.
Yep ...
1,100 HP on a 91 octane tune!
I mean...really!
The guy paid 500 grand for the car and he can't afford to run race gas, E85, or Meth injection....!!!??
That twin turbo SOHC would crank out 1,500+ HP without even breathing hard!
