Results 1 to 15 of 25
Thread: Door Keypad code?
    Oct 2008
    Clarksville, TN
    Door Keypad code?
    Hi all, THe MM I just bought didnt come with a owners manual or the code for the door keypad, can anyone point me in the right direction for getting these things? Also my MM has the power adjustable pedals is that a standard MM option or what??
    Thanks
    04 Black (Charcoal int, Sunroof, Heated Seats, CD Changer)
    #2497 Born on 4/19/04, Adopted on 10/11/08
    As best as I can figure she is a 2004, 1 of – 1245 Black, 1059 Char Int, 842 CD changer, 873 Heated Seats, 508 Black Sunroof.
    So not super rare but She is mine and 1 of a limited Breed of Cars!
    Currently Bone Stock with about 55K miles (soon to change)
    Purgatory, FL
    Adjustable pedal were standard on the MM. As for getting the door code, you could remove the driver door panel and look at the keyless entry module or have a dealer access it via computer for a fee.
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
    Oct 2003
    Beaufort, SC
    Look on your trunk hinges (white sticker)....mine was CLEARLY VISIBLE to passersby on the driver's side hinge....Grrrrr!!! Needles to say I moved it!!
    It's also located on the lower portion of the "A" pillar, drivers side.
    The stickers came with the owner's manual, some dealers installed them in the traditional spots, some new owners did the same, and some were never installed. Pull the driver's door panel and it is clearly visible on the door control module.
    Shoot me a PM, I may be able to help with the owner's manual.
    Aug 2008
    Texas
    Mine are on the driver's side trunk hinge, inside the left side of the glove box, and inside the driver's door panel.
    Arizona
    Mine wasn't posted anywhere when I got it and the stickers didn't come with the car.The dealer looked up the current code number for me with the machine but it's not the original number which means until I pull the door panel and get the original number I can't change the code to the numbers I want and I'm stuck with the previous owners numbers.
    Member #462
    2004 DTR II
    2005 H-D E Glide Classic
    2009 Super Glide Custom
    Oct 2004
    Christian Co. MO
    the panel comes off effortlessly, there are non-wear clips, typically you can remove it as often as you wish without damage.
    03 Black sequence number #2228 of 7838. First day of Gold Coolant.
    Dec 2005
    Layton, UT
    Yea, pull the door pannels off...
    Its so easy...a caveman can do it.
    Matt H.
    (sold)2004' SB, 268rwhp/295tq
    2017 F-150, 5.0
    2013 SHO DIB Performance Pack
    Aug 2004
    Fairfield, PA
    Quote Originally Posted by UncleLar View Post
    I believe there's something wrong. As I understand it, the original code will always work, no matter how many user changes have been made. If the dealer looked it up, perhaps there was a mistake in either the question (incorrect VIN) or the answer. I suggest having him double check. Also, it seems odd that those numbers have been removed from the trunk, etc. unless there was body repair or replacement of the doohickey that reads the door button codes. Does your key fob thingey work?
    Apr 2006
    Long Island
    Quote Originally Posted by Mike Poore View Post
    Yes the original code should always work. Even if the DDM (drivers door module) was replaced the scanner will show the code for the new module.
    If his keypad has a bad button, that may be his problem??
    Arizona
    Both key fobs work fine and the door locks and unlocks fine also with the numbers the dealer was able to access.
    Evidently the selling dealer never placed the numbers on the car,they're out of business so I can't contact them.I have the former owner's name but not her location or any contact info for her.
    No big deal to pull the panel,one of the mods I have planned for the future is replacing the stock speakers.
    Member #462
    2004 DTR II
    Lehigh Valley, PA
    Fix your sig, its a 300A not 300 B
    It should be on the drivers door once you take the panel off.
    BTW, if you have your keys inside the car, dont hit 7/8+9/0 at the same time with all doors locked, cause you will lock yourself out with the keys inside the car
    2063/3214
    5377/7838
    Oct 2008
    Clarksville, TN
    Sorry OffRoadkarter, "Fix your sig, its a 300A not 300 B " Sig is Fixed. In my initial research of the site and my car I thought all MM's where 300As or Bs, at first I didnt know that basicly all 04 are called 300A even though they arent the same as the 03 300As kind of confusing to a newbie. I wish I had the auto brake release, Fuel Door and what not on mine. Oh well, thanks for pointing that out.
    Aug 2004
    Fairfield, PA
    Quote Originally Posted by MercDwarf04 View Post
    There's more, and don't feel badly because you're confused about the differences. Turns out there are some not fish nor fowl in between ones that were "decontented" with some having some of the "A" stuff and some of the "B" stuff and all sorts of various combinations. Basically the 2003 "B" and the 2004 are most alike. Check out the sticky that explains most of it; but try not to understand all of it, as those who claim to know everything about the differences ....may not.
  1. Garage door opener (homelink system)
    By Matt In Detroit in forum Community Discussion
    Last Post: 06-16-2016, 01:59 PM
  2. Engine code help!
    By Joe Walsh in forum Shop Talk
    Last Post: 05-21-2009, 01:52 PM
  3. U1000 code
    Last Post: 10-11-2005, 09:13 PM
  4. Who ownes the tune?
    By TooManyFords in forum Tuning
    Last Post: 09-28-2005, 10:04 PM
  5. Need Info?
    By PJR in forum Community Discussion
    Last Post: 07-13-2005, 07:58 PM
