Results 1 to 15 of 19
Thread: Abs and vaps
    Jul 2008
    Germany
    Abs and vaps
    After 2.5 years my ABS-Module from my Marauder 2003 the second time defective.
    The first time i had several DTC´s and the TC, the yellow ABS and the TC switch was glowing.
    After replace of the module, everything was okay. But since two days the yellow ABS indicator and the TC indicator illuminate again, but w/o the traction control switch. I connect the car with an IDS and get the DTC C1300 (ABS Pump Motor Circuit Failure) and C1897 (VAPS circuit failure).
    Can that be true, that i need after 30 Month the second module? It is dry sand no corrosion at the pins. In different Forums, i read that the VAPS get power from ABS Module, about the VSS.
    Can someone help me? I don´t want to change the module again, it is very expensive!!!!!
    Marauder 300A from 2003, one of two in Germany!
    #6020 of 7093
    2MEHM75V93X658764
    WITH LPG
    An alternative is a company called Module masters here in the states, $200 and shipping, and a 5 year warranty.
    I have had luck with the connectors having oxidation on them before, a little de-ox and they were working again. I am not 100% sure if the VAPS gets it's power from the ABS, I would need to research that, but I would say no, I believe it is on a separate circuit.
    I would start with checking all connections, verifying power and ground to the circuits with a DVOM, then proceed from there, if both quit at the same time, I would lean towards a chafed wire or a bad power/ground circuit.
    Trilogy # 192 / T.S. 0012
    Jul 2008
    Germany
    company callused module sounds good. can you gimme a homepage or address, please?
    #6020 of 7093
    2MEHM75V93X658764
    WITH LPG
    Hiram, Georgia
    Quote Originally Posted by Coupe View Post
    I believe this is the place Darrin is talking about:
    http://www.modulemaster.com/en/index.php
    Jul 2008
    Germany
    unfortunately there isn´t Mercury in the list!
    #6020 of 7093
    2MEHM75V93X658764
    WITH LPG
    Oct 2004
    What is a DVOM ?
    Derby City, KY
    What is a DVOM ?
    Brought to you from Wiki...
    http://en.wikipedia.org/wiki/Multimeter
    Mike.
    They are not on the list, you need to call or email them, they WILL rebuild your module. I had them do a couple for me that "weren't on the list".
    Good luck. I would seriously look for voltage or ground faults before changing parts.
    VAPS is combined in one module with the RAS. That module gets its power from fuse 114 in the BJB and fuse 16 in the cabin fuse box. Nothing to do with the ABS.
    The ABS module gets power from fuses 118 and 106 in the BJB and also from fuses 14 and 11 in the cabin. It gets is signals from the 4 wheel speed sensors, not from the VSS.
    Without access to a WDS, you can try the following:
    Disconnect the ABS control module connector and check for >10 volts between pin 13 and ground (earth) and between pin 14 and ground. You can also check for proper grounds resistance from pin 12 to ground and from pin 15 to ground. (should be <5 ohms). Note: these readings are all from the harness side, not on the module itself.
    Jul 2008
    Germany
    thank you, i wrote them a mail!!
    what means RAS? i have an IDS/VCM scanner, the told me this faults:
    Uploaded with ImageShack.us
    #6020 of 7093
    2MEHM75V93X658764
    WITH LPG
    RAS = Rear Air Suspension
    Some of the codes in your screen shot make no sense and I can't find any info about them. One that DOES make sense is B1318 - RASM. That code mean Low Battery Voltage at the module. Combined with the versagt (failure) of the VAPS (which is the same module) points to some other electrical failure, possibly with the wiring. The FSM (factory service manual) also states that this code can be set by a battery in a low state of charge.
    Check for >10V at pins 1, 15, and 16 (referenced to ground). Also check for <5 ohms of resistance between pin 6 (of the harness side) and ground with the harness disconnected.
    C1897 is Steering VAPS Circuit Loop Failure. If you get everything else cleared and this remains, I can scan the test procedure and post it.
    Jul 2008
    Germany
    i´ll replace next week the HCU, because in the failure tree diagram shows the system, that C1300 is s defective ABS module or HCU module, may is the electric pump defective. but also i check every connectors and wirings. i´ll update you with the solution. thank you so much for help!
    #6020 of 7093
    2MEHM75V93X658764
    WITH LPG
    Du bist herzlich willkommen, mein Freund.
    Jul 2008
    Germany
    Du sprichst deutsch?
    Okay, komme gerne drauf zurück!
    #6020 of 7093
    2MEHM75V93X658764
    WITH LPG
