Results 1 to 7 of 7
Thread: cooling mod
    mark c Guest
    cooling mod
    what's this "cooling mod" i see talked about on the forum?
    I will be towing a trailer & want my marauder to stay cool!
    The rear cylinders are known to run hotter than the fronts due to a miscalculated design. The coolant sits somewhat stagnant in the back of the head with no where to go, thus producing higher temps. The cooling mod works by popping out the freze plugs in the back of each head, installing a perfect fit piece and tying both sides into the heater system.
    You can do it without taking out the trans, but it is difficult.
    Ive done 3 so far. If you live close, I can help.
    hitchhiker Guest
    Quote Originally Posted by Zack
    Zack, do you have a parts list and any pictures for this cooling mod?
    Thanks,
    David
    I bought the kit from Dennis
    hitchhiker Guest
    How much is this cooling mod kit?
    What parts does it consist of?
    Thanks,
    David
    Quote Originally Posted by hitchhiker
    Thanks,
    David
    check out this thread
    http://www.mercurymarauder.net/forum...***.php?t=7892
    Mar 2003
    Los Angeles
    I just received my P.I. Stallion torque converter and Reinhart Automotive engine cooling mod from Dennis. Makes sense to do the install together, right? What do you all think a reasonable labor total would be for both installs? Thanks!
    P.S. Dennis doesn't like to post his prices in the forums, he prefers you call (reach him at 904.276.5003 from 8am-5pm Eastern time)--also, I haven't picked up the cooling mod kit yet from my office, so I don't know what's included.
  1. best first mod for MM
    By Crazieboutamerc in forum Community Discussion
    Last Post: 01-23-2004, 09:16 AM
  2. Jerry's Transmission Mod
    By Marauderer in forum Shop Talk
    Last Post: 10-15-2003, 07:36 AM
  3. poll..first mod for 04 mm...
    By ANGRRMGT in forum Community Discussion
    Last Post: 10-10-2003, 10:25 AM
  4. what is a throttle body bypass mod?
    By the fat bastid in forum Shop Talk
    Last Post: 09-02-2003, 08:51 AM
  5. To mod or not to mod? That is the question...
    By Heavy D. in forum Community Discussion
    Last Post: 05-21-2003, 06:33 AM
