Page 1 of 4 1234 LastLast
Results 1 to 15 of 57
Thread: My Turbo Build Pics
    My Turbo Build Pics
    Since I wasn't around when I wrecked the car, rebuilt it and fabbed the turbo kit, I figured Id share everything that went into it. Enjoy
    Day of the wreck in Kentucky:
    Got ran off the road and Dukes of Hazzarded the car. Lots of frame damage, wrinkled roof, wrinkled drivers quarter panel. Everyone said you cant fix that....yeah ok.
    Scored all this on CL for $1200, and a bunch more not pictured:
    This area was really bad:
    On the frame rack:
    It came down so hard that the firewall was wrinkled causing the front end not to fit. I had to shim the body off the frame about 1/2" with huge grade 8 washers.
    I started everything based off this flange:
    Then built the crossover pipe:
    Continued.....
    I took 1/4" off the AC compressor body so it would hug the engine better. That's a 3" pipe pictured:
    Moving along;
    Wastgate plumbing:
    Downpipe:
    I lowered the ABS module and moved it back. No re-making of brake lines necessary
    Fits with ample clearance:
    Mustang fan flipped upside down, and simple aluminum brackets. This fan barely cuts it...im upgrading this year:
    Simple bracket made to relocate the AC drier and hoses:
    All of the piping before coating:
    At my friends shop for paint work:
    Drivers side wheel liner modified for the downpipe:
    All done:
    Then I got aggressive and hurt a few pistons. I had to hurry up and get the shortblock fixed in 2 weeks to make it to MV11.
    I never got a clean dyno since I had to upgrade the valve springs. Im going back in March for a 93 and E85 tune.
    Here's a vid right after I put the springs in:
    I have since installed a Circle D 4k Converter which is exactly what the car needed. Its a blast to drive.
    Good stuff
    Jul 2012
    Florida
    Nice work!
    'Just Live'
    Jun 2010
    essextrash, maryland
    Holy **** that things fast! I dont know how you do it man, if i had twice the know how i have now id only be a 1/4 of you. That things badazz!
    Apr 2010
    Western Canada
    Oct 2011
    Westport, Ma
    Great story glad you saved it
    2003 MM 300A
    #738 of 7,838 BLK
    Build date: 6/6/2002
    Adopted: 2/05/2013
    MODS:
    Metco control arms, Addco sway bars, TCE brake lines, Gatorback belt, remote start, underbody lights, custom doorsills. Black with custom silver hood stripes (S-55 theme)
    2004 CV LX SPORT
    ALL BLACK, 6 DISC, TUNED MZT
    Adopted on12/09/18 from chief455
    COMING SOON-Trilogy #005 THANKS CWright-
    I am afraid you have awakened a sleeping Giant
    http://www.mercurymarauder.net/forum...=view&id=14156
    Quote Originally Posted by MOTOWN MARAUDER View Post
    Im happy for you bro! Let the mods begin! I hear the mod bug broke his stinger when he heard you pulled the trigger!
    BIG BIG thanks to the GOD of marauder parts ( Darren) I am the 1st winner of Darren bag of fun give-away
    Sep 2006
    Clermont Florida
    Awesome as always..
    Feb 2012
    harrison twp,mi
    Nuff said
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    Now that's a killer 'home-brew' turbo kit!.......
    Awesome work Zack!
    Must be a fake speedometer in that video....it is sweeping WAY TOO FAST....
    BTW: You've got some BIG hot side pipes really close to some other components...are you worried about unintentionally cooking stuff?
    Also, is there anyway to run that big air filter/intake farther away from the hot radiator air?....maybe a 90 degree turndown?
    Jun 2005
    East Lansing, MI
    Very nice, I love the sound of the turbo spooling
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    Awesome work Zack!
    With the heat wrap I have had no issues. Ive put 2k miles on the setup.
    As for the air filter, Ive had no issues with that either.
    IAT's at WOT are 20-40 over ambient. Pretty acceptable to me. I have a good Treadstone intercooler on it.
    You can grip the wrapped hot side pipes for 5-10 seconds before you say oh ***** that's hot
    Oct 2010
    Michigan
    Very nice indeed!
    What kind of fuel injectors?
    North Aurora, IL
    Seeing that car at Louisville wrecked was a heart breaker. But to see it the following year better than ever was amazing Zack.
    You are a master Zack.
    Sent from The White House on taxpayers dimes.
    DTR + 4.10's + Eaton swap = Wreeeeeeeeeeeeeeedom
    Great quotes!!
    Eat poo poo and die heathen.
  1. Zack's Turbo MM Build!
    By ctrlraven in forum Power Adders
    Last Post: 07-07-2013, 11:25 PM
  2. My build is done!!!
    By camelgrundle in forum Power Adders
    Last Post: 03-05-2013, 10:11 PM
  3. How do i find my build date, build # , 300a/b ?
    By dj_pizm in forum Community Discussion
    Last Post: 03-03-2010, 05:18 PM
  4. MGM Turbo Build
    By ludwigvan968 in forum Shop Talk
    Last Post: 11-28-2009, 07:24 PM
  5. 6.5 Turbo Diesel Intake Pics
    By blazen71 in forum The Lounge
    Last Post: 11-03-2008, 09:15 AM
