Results 1 to 11 of 11
Thread: Windage Tray
    Oct 2004
    MIA
    Windage Tray
    Has anyone installed this windage tray? Being that we MM owners likey the high RPM's. Does the install involve taking down any other major components besides the oil pan? price isn't too bad. Does DR have the hookup?
    SILVER 04MM
    uhh, I'm sorry - what does it do again?
    TRILOGY № 86 - 13.5PSI
    Oct 2004
    MIA
    <BIG>CANTON RACING PRODUCTS, 4.6 / 5.4 FORD WINDAGE TRAY KIT</BIG>
    (NOTE: Moroso Eliminator 7 Quart Aluminum Oil Pan listed at bottom of this page)
    What does a Windage tray do?
    Windage is the flow of air within the crankcase. Each time a piston comes down in the piston bore the air under it is pushed into the crank area and each time the piston goes up the air is pulled in behind it. In a eight cylinder engine all eight pistons go up and down each revolution. At the same time the rotating assembly is spinning and churning the air. Oil coming off of the crank is also put into the mix. So as the RPM increases so does windage. At 6000 RPM’s the assembly is rotating 100 times a second.
    A windage tray keeps the windage around the crank from the oil in the sump area. It allows oil coming off the crank to easily enter the sump without the windage affecting the oil already in the sump. Windage trays keep the oil in the sump from getting into the rotating assembly when the action of the vehicle is in motion increasing 15 to 18 Hp at 6000 RPM.
    SILVER 04MM
    Los Angeles - California
    very interesting. would like to hear more.
    anyone?
    bueller?
    bueller?!
    2004 BLACK MERCURY MARAUDER
    SCT
    JLT Cold Air Induction
    PHP Intake Spacer
    Cobra Ported Manifolds
    Flowmaster 50's
    Magnaflow X-Pipe
    Stallion TC
    4:10's
    Steeda Underdrive Pulleys
    Rear sway bar
    1969 GREEN MACH I MUSTANG GT
    351 Windsor
    Shelby Cam
    Shelby Tri-Y headers
    Ported and polished heads
    10.5:1 Domed pistons/rods
    Balanced and blue-printed
    Offenhauser Intake
    NOS plummed under intake (8 fuel injectors, 8 NOS injectors)
    Art Carr TC
    Tranny shift kit
    Dual ignition with MSD
    3:90 Posi rear end
    Bought car when I was 16 and still have it
    Oct 2004
    MIA
    on a quick research, i found jegs has the ford racing windage tray
    (PN# M-6687-D46) for 33.99. later
    SILVER 04MM
    The Marauder motor has a type of windage tray already I will post pictures of this tomorrow
    Oct 2004
    MIA
    thanks DR. do you know if the Harley Davidson S/C pickups have them also?
    SILVER 04MM
    Here is a picture of a stock Marauder its not bolted in and this just came from Ford check out the rust will clean it up and add the corect studs for this install
    Jun 2004
    Quote Originally Posted by Dennis Reinhart
    Dennis, is the FORD OEM windage tray removeable?
    Quote Originally Posted by rayjay
    Yes its real easy with the pan off of course
    Jun 2004
    Dennis, is the OEM tray worth replacing with a aftermarket one? Looks like the one 1st posted about here is a better design, but I'm certainly no expert.
  1. Golf Club trunk tray insert
    Last Post: 11-26-2004, 06:34 AM
  2. Rattling from Speaker Tray
    By LVMarauder in forum Shop Talk
    Last Post: 04-20-2004, 07:13 AM
  3. Sub-Woofer with amp. in trunk dosen't work ?
    By warren in forum Community Discussion
    Last Post: 04-11-2004, 09:01 PM
  4. SubWoofer Rattle and Passenger Window Switch
    By cyled in forum Community Discussion
    Last Post: 12-29-2002, 06:29 PM
