I've got to hand it to you "D-I-Y Eaton" guys....
I must be getting old, because I definitely do NOT have the time or patience to shop, haggle, hunt down and attempt this mod.
I'd just call Trilogy and be done with it, regardless of how much $ savings I missed out on.
