My Alma Mater just blew up the NCAA brackets with a 'never... ever been done before' performance!
The #16 seed UMBC Retrievers eradicated the #1 seed Virginia Cavaliers 74-54 last night!!
Nice win! Good luck against Kansas St.!
Just goes to show ya Joe.......ANYTHING can happen!!
