MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 02-10-2019, 06:45 PM
hudskit hudskit is offline
Junior Member
Trader: (0)
Is the wire running from the Alternator to the battery still available?
I cannot find the parts number and I think that's the cause of my newest problem. The battery light comes on occasionally - simultaneously the voltmeter drops down to below 14 - guessing 13.8 or so - while the battery red light is on - and then I hit a pothole and the red battery light turns off while at the same time the voltmeter pops back up to a little under 15v - had it on the oscilloscope and everything checks out so it's got to be that set of wires in my mind . I already replaced the clip end that goes into the alternator - so it has to be somewhere in the rest of the line.... unless some has a better idea?
  #2
Old 02-11-2019, 08:46 AM
fastblackmerc's Avatar
Trader: (75)
Sounds like a loose and or dirty connection.
__________________
  #3
Old 02-11-2019, 11:52 AM
the fat bastid's Avatar
the fat bastid the fat bastid is offline
Kneel before Zod!
Trader: (6)
I agree with fbm, but if you need that harness I have one.
__________________
garage
  #4
Old 02-11-2019, 12:46 PM
Trader: (75)
Make sure the grounds are clean and tight.
__________________
  #5
Old 02-12-2019, 09:27 AM
Trader: (75)
Can can make a cable for you out of 4 gauge wire and copper terminals.
__________________
  #6
Old 02-12-2019, 03:21 PM
Junior Member
Trader: (0)
Thanks for all the help, guys - but could someone suggest which ground locations to check? I figure it will be easier to find the correct ones to remove , clean and reconnect if I could get a little help on where to look....
Thanks a million , guys - and thanks Fat Bastid for the new( er) harness!
  #7
Old 02-12-2019, 04:04 PM
Trader: (75)
All the grounds in the engine compartment.
__________________
  #8
Old 02-13-2019, 08:44 AM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
@ the OP: that line from the alternator to the battery stud on the BJB isn't just a piece of wire. It also has 2 #12 fusible links in parallel with each other, in series with the #6 red wire. DON'T replace it with just plain wire.
__________________
  #9
Old 02-13-2019, 09:26 AM
Agent2006 Agent2006 is offline
Senior Member
Trader: (0)
http://www.idmsvcs.com/2vmod/starter...s/PICT7235.jpg
any body have a list or pix of all the grounds on these cars? (underhood , etc) 2003 wiring manual is not as helpful as I might like. Here's the battery harness , at least shows you where two of them are.
  #10
Old 02-14-2019, 06:54 AM
Junior Member
Trader: (0)
Thanks for the pic - very very helpful
Thank you very much for this - like you I have found that the manual is not all that helpful . When I had my troubles with the dome light not turning off it took me days to trace it back to a bad ground in the right rear door, of all places- which when cleaned up and reattached solved that particular trouble for me.
Are there any more grounds that should be checked/serviced in the engine compartment area?
  #11
Old 02-14-2019, 07:27 AM
Trader: (75)
Grounds are on the passenger side fender by the battery, on the front of the engine block and the top of the passenger side cam cover to the firewall.
HINT: look for the NEGATIVE - BLACK wire from the battery.
__________________
  #12
Old 02-15-2019, 05:41 AM
Junior Member
Trader: (0)
Thanks- since I'm replacing that wire I will definitely hit those 3 -Thanks!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
alternator? battery? help! iamjimmy Shop Talk 14 06-13-2017 09:59 PM
What powers the car when running, the ALT or the Battery? SIZEMOREMK Shop Talk 15 10-26-2015 07:24 AM
Trilogy Alternator Wire Fail JohnE Power Adders 12 08-19-2015 05:30 PM
New Battery and Alternator - Battery Light Still On blackf0rk Shop Talk 62 06-21-2010 10:07 AM
Alternator Power Wire cougar9150 Shop Talk 5 12-14-2009 02:30 PM
Powered by: vBulletin
