Results 1 to 15 of 15
Thread: oil usage first few hundred miles
    Jun 2017
    Oxford, PA
    MM back on the road after a long sleep - ~3 years
    no smoke on start up --no smoke while running, car runs great!
    ---either a stuck PCV valve...getting a new one MONDAY
    ---or she's got a drinking problem. 1 qt 5W-20 in 320 miles.
    maybe it will settle down, dry valve stems seals, light ring rust...
    I'm going to 5W -30 full synthetic...might try an additive to soften up the umbrella seals...any ideas here? By the way, if it winds up a qt every 600-800 or even 1000 miles I don't care that much..I see only one PCV valve on the pass side, there is NOT supposed to be any thing on the drivers side valve cover expect a hose--correct?
    Dec 2018
    Albemarle,NC
    Lucas heavy duty oil stabilizer.Have used this for years in most of my vehicles. Have a 87 5.0 Mustang that burned a qt. every 500 miles when I bought it with 83k miles.Use Lucas in it every oil change slows it down to a qt every 1500 miles at first as it burns it off it loses about 300 miles ea qt by the time it needs another oil change it's back at close to 500.It now has 249k on it. I'm not a big fan of additives & magic cures but the whole line of Lucas products actually work as advertised.
    Jun 2017
    Oxford, PA
    OK here's the plan:
    -switch to high mileage 5W-30 Walmart full synthetic/Motorcraft filter (of course)
    -new PCV valve fromFord
    -oil separator from Harbor Freight plumbed into pass side PCV line
    -lucas oil stabilizer
    -lucas fuel injector cleaner (in case one injector is washing down the cyl walls
    thoughts?
    The Dirty South
    Verify the flter element is designed for synthetic oil.
    Most air separators are not
    Dec 2018
    Albemarle,NC
    OK here's the plan:
    thoughts?
    Sounds good to me just check on the separator like musclemerc said.
    Jun 2017
    Oxford, PA
    Thanks guys...good responses...
    I'm thinking: the difference between a synthetic oil separator and a non-specific one would be mesh size, the HF one is 40 micron ...and the difference between dino oil and synthetic is one oil is lower viscosity even when cooled. So! a separator designed for air compessor oil ought to do the job. I'll post pix of my set up.
    Feb 2017
    New Orleans, LA
    my 03 marauder has 254k miles on her and takes a quart about every 2k miles
    I would say your consumption is quite high
    Jun 2017
    Oxford, PA
    Also can be a bad pcv valve ....getting a new one tomorrow from Ford....fyi 2v and 4v are different according to the partsguy
    Dec 2009
    Phoenix, Arizona
    Mine uses about half a quart or a quart every 4,000 miles.
    New PVC valve, and JLT oil separator, but it does have an oil seap
    2004 SB Mercury Marauder
    2003 Mercury Marauder 300B
    Jun 2017
    Oxford, PA
    Hmmm...
    160 miles on the new oil change to 5W-30 Synthetic and additive..Dipstick reads FULL.
    maybe
    ---light rust on the oil rings during a 2 1/2 year hiatus
    ---dried out valve stem seals
    ---skunk 3 year old gas washing down the cyl walls instead of burning cleanly
    ---the higher wt oil mentioned above
    will continue to monitor!
    Oct 2008
    Massachusetts
    Hmmm...
    maybe
    Sounds promising!
    Jun 2017
    Oxford, PA
    450 miles and still full !...
    Jun 2017
    Oxford, PA
    600 miles and 1/2 Qt down...my additive must not be sealing up the valve stem seals as well...on the plus side not much oil in the catch can. Must not be getting a bunch of blow by past the rings
    Jun 2017
    Oxford, PA
    Update to the update 800 miles and still full, must have pulled the dipstick too quick at the 600 mile check. So it was not 1/2 qt down afterall.
    Lesson learned. I was in a hurry. Let these big wide heads drain all the way back down before checking the oil.
    Oct 2008
    Massachusetts
    Good news!
  1. Best mod for a couple hundred bucks??
    By Evasfunk in forum Community Discussion
    Last Post: 10-06-2007, 07:49 PM
  2. The Five Hundred GT-R
    By Sully008 in forum The Lounge
    Last Post: 03-11-2006, 03:33 PM
  3. Ford Five Hundred review
    By Eric91Z in forum The Lounge
    Last Post: 08-04-2005, 10:58 AM
  4. Pictures of our Ford Five Hundred
    Last Post: 06-14-2005, 06:05 AM
  5. REVISED SPARK PLUG USAGE for 4.6L
    By schuvwj in forum Shop Talk
    Last Post: 02-27-2005, 12:57 PM
