Results 1 to 15 of 30
Thread: Brake and abs light on after new tires.
    Apr 2016
    San Francisco, Ca
    Hey guys. Just have a dumb question. I just recently changed the front tires of my car. They are 255 45 18. I know that not having the stock wheel size will set off the brake light and abs light on the dash after you stay over 60mph. The lights go away after I turn the car off then come back on. Is their a way to reset the sensor or adjust it so it wont power on anymore. it didnt do this before with the same size tires only after I replaced them.
    what size are your rear tires?
    Quote Originally Posted by BlackBeauty_bb View Post
    You either have to manually turn traction control off, turn traction control off in a tune or put the right size tires on all four corners.
    May 2009
    Moreau Island
    Is your car an '03 or an '04? If it's an '04, the advice FBM suggested might solve the problem. If it's an '03 there may be a different issue. Is there a chance the service person knocked the ABS sensor loose while changing the tires?
    Oct 2005
    Southwest Florida, Lee County
    Was this after tire replacement or was it a coincidence? My buddy has an '04 and his ABS/brake lights would reset after turning the car off/on. His issue wound up being the ABS module on the ABS ass'y under the intake.
    2004 Mercury Marauder
    2,187 of 3,214
    997 in Silver Birch
    448 with light flint interior
    304 with heated seats
    336 with sunroof
    Apr 2016
    San Francisco, Ca
    RE;
    The rear tires are 275-45-18. This issue only happened after I replaced the front tires. before that the car had the same size all around. So that was what threw me off guard. And I took it back to the shop and they didn't find anything wrong. my rear tires are running very low on thread so Im also wondering if that could be a possibility.
    Apr 2016
    San Francisco, Ca
    And my car is a 2003.
    Check all the ABS sensors at each wheel. You might find them loose.
    You need larger diameter rear tires.
    May 2009
    Moreau Island
    If it's a 300A tire size won't matter. Check the ABS sensors to make sure they are on tight
    It does on mine.
    May 2009
    Moreau Island
    Why? I was under the impression you can run what ever you want on a 2003 300A. Based on your join date I assume your is an A unless you joined before you bought yours and you have a 300B.
    It doesn't have traction control so it doesn't screw up the power delivery, but it does make the abs and brake light on the instrument panel come on. Sometimes people get away with the same size all around, but if the rears are slightly smaller than the fronts you have this issue.
    That silver birch of yours at Louisville has 260k???!!!????
    Wow, I had no idea
    Nice Brian
    May 2009
    Moreau Island
    So if the OP has 275/45/18 on the rear and 255/45/18 on the front, why would this screw with his idiot lights?
  1. For Sale 3rd Brake light (CHSML) - Light Flint
    By CrownVictorious in forum Marauder-specific Parts for Sale
    Last Post: 08-19-2015, 12:40 AM
  2. Brake light on
    By Flbatfish in forum Steering, Suspension & Brakes
    Last Post: 04-29-2014, 06:28 AM
  3. Wanted To Buy Third Brake Light
    By marauder'10 in forum Marauder Parts/Misc. Wanted
    Last Post: 07-25-2012, 05:50 AM
  4. E-Brake Light coming on (not ABS light)
    By rickey1987 in forum Shop Talk
    Last Post: 12-23-2009, 10:42 AM
  5. Replies: 9
    Last Post: 08-04-2009, 08:28 AM
Tags for this Thread
