i was wondering what is evaporative emission control system leak detected small leak ............what is it and how do i fix it thanks
Try this. Remove your gas cap and then tighten it back up. I had this code on my wife's Taurus and thissolved the problem.Originally Posted by 59chev348
383 4-speed w air grabber
Thats covered under the 8 year 80K mile Federal Emissions Warranty. Take it in and let the dealer repair it.
'15 F250 CC 4WD 6.7L PSD
'11 CVLX
'05 E55 AMG
'91 350SD Turbodiesel
'97 Land Cruiser/78 Land Cruiser
thanks i will try that and i will give the dealer ship a call
to say its covered under emissions warranty isnt really accurate becxause we still dont know the exact cause of the problem....from my experiences at the dealer it has mostly been gas cap concerns...but occasionally you get a rotten evap hose or a purge valve /solenoid that is not working...but ive never seen any of those repairs covered under federal warranty...if you go to the dealer id be prepared to pay a bill....unless youre covered under bumpper to bumper still....the 8/80000 emissions warranty is quite limited in what it covers....
former owner...2003 marauder black
vortech air/air reichard 3.4 pulley
dr exhaust w/ mac stainless mufflers
baer 14in brakes, stainless hoses
4.30's
31spline mosers, auburn pro, tfs girdle
dynotech shaft
305 nittos
sold!
Try the cas cap idea then disconnect the battery for about 10 minutes. This will reset the computer. When you restart the car you will find out it that was it our not.
11.98 @ 115 mph"Comfort, Class and Hair on Fire Performance."
when you restart the car after disconnecting the battery the light will most definitely be off but that does not mean the problem is gone. the pcm has to go thru a drive cycle and monitor the evap system...if the fault is still present it will put the light on. it may take a couple days to complete one drive cycle....
4.30's
dynotech shaft
305 nittos
sold!
Originally Posted by thePunisher
Straight out of the Manual...I have taken vehicles in with 60K on the clock for a faulty purge solenoid, DPFE Sensors, etc and the dealer has replaced them, so who knows. I'm not saying the dealer is or isnt going to pay for it, I'm just reading waht the manual says and what my personal experiences are, but they also have the smoke machine that can be plugged into the EVAP Service Port to look for leaks. Easier to pay an hour labor than crawling all under the car and checking every line and the cannisters etc.
I think a 'faulty gas cap' is a wild guess at this point, theres a seprate gas cap light on these cars IIRC. My moneys on a cracked line or a purge solenoid.
Heres a TSB Also."List of Parts Covered by Emissions Warranties for Cars, Light Duty Trucks, And Heavy Duty Vehicles"
Air Flow Sensor
Air/Fuel Feedback Control System and Sensors
Air Induction System
Altitude Compensation System
Catalytic Converter
Cold Start Enrichment System
Cold Start Fuel Injector
Controls for Deceleration
Electronic Ignition System
Exhaust Pipe (Manifold to Gasket)
Electronic Emissions Control Unit (ECU)
Electronic Engine COntrol Sensor and Switches
Evaporative Emission Control System
Exhaust Heat Control Valve
Exhaust Gas Recirculation Valve
Exhaust Manifold
Fuel Filler Cap and Neck Restrictor
Fuel Injection System
Fuel Injector Supply Manifold
Fuel Sensor
Fuel Tank
Fuel Tank Pressure Control
Idle Air Bypass Valve
Ignition COil/and or Control Module
Intake Manifold
Intercooler Assembly/Engine Charger
Malfunction Indicator Lamp (MIL)
PCV System and Oil Filler Cap
Powertrain Control Module
Secondary Air Injection System
Spark Control Components
Spark Plugs and Ignition WIres
Sychronizer Assembly
Throttle BOdy Assembly
Transmission Control Module (TCM)
Turbocharger Assy
NGV Module
Also Covered are emissions related hoses, bulbs,clamps, brackets, tubes, gaskets, seals, belts, connectors, non diesel fuel lines, and wiring harnesses associated with the above mentioned guide.
FORD:
1997-2000 CONTOUR
1997-2001 CROWN VICTORIA, ESCORT, MUSTANG, TAURUS
2000-2001 FOCUS
1997-98 F-250 HD
1997-99 F-250 LD
1997-2001 ECONOLINE, EXPEDITION, F-150, RANGER, WINDSTAR
1997-2002 EXPLORER
1999-2001 SUPER DUTY F SERIES
2000-2001 EXCURSION
2001 ESCAPE
LINCOLN:
1997-98 MARK VIII
1997-2001 CONTINENTAL, TOWN CAR
2000-2001 LS
1998-2001 NAVIGATOR
MERCURY:
1997-99 TRACER
1997-2000 MYSTIQUE
1997-2001 GRAND MARQUIS, SABLE
1999-2001 COUGAR
1997-2002 MOUNTAINEER
ISSUE:
Some vehicles may exhibit a Malfunction Indicator Lamp (MIL) illuminated with Diagnostic Trouble Codes (DTCs)
P0455, P0456, P0457, P0442, P1442, P1443, P1450 or P1455 for the Evaporative Emission system. This may be
caused by loose or leaking hoses, loose or broken fuel cap, etc... A leak at the top of the fuel filler pipe neck between
the filler pipe and plastic insert is often misdiagnosed as a fuel filler cap leak
'11 CVLX
'05 E55 AMG
Emissions warranty is exactly what it is... EMISSIONS WARRANTY.Originally Posted by thePunisher
It is stated by what WCHAIN has posted and it is MANDATED by our FEDERAL GOVERMENT.
ALL EMISSIONS RELATED PARTS ARE COVERED FOR 8 YEARS AND 80,000 MILES FROM THE IN SERVICE DATE OF YOUR VEHICLE.
PERIOD...
NO DEDUCTIBLE
NO CHARGES
NO GET OT OF JAIL FREE CARD EITHER
Pete...
DOB 10/31/2003
DOP 1/2/2004
DOB 12/11/2018
DOP 6/19/2019
Safe to say I voided most of that warrenty too.
Do you even HAVE a warranty left ???Originally Posted by Defyant
Pete...
DOB 10/31/2003
DOP 1/2/2004
DOB 12/11/2018
DOP 6/19/2019
It's not always a warranty issue...
Mine was caused by a shop that drilled several small holes in my gas tank, while installing an amplifier.
And yes, the shop in question paid the $1300 repair bill promptly.
the list varies by vehicle...i see you have spark plugs listed there....no way plugs are covered under federal....unless my delaer is doing something wrong...most of those things i almost always repair under pay work...the only parts i see go federal are cats and pcms most of the time...even dpfe sensors are always pay work...unless there is an open recall on them....ill see if i can check today...there is a book with all covered items at work...
4.30's
dynotech shaft
305 nittos
sold!
I had the same issue. I checked the cap and reset the fault but it came right back. I took it into the dealer and it ended up being a loose hose in the evap system, just like the TSB says.Originally Posted by 59chev348
