Results 1 to 15 of 20
Thread: My Take On Pulleys................
    TX
    Unhappy My Take On Pulleys................
    While at Fun Ford in Houston I bought a set of Steeda Pulleys.
    First off they are very high quality.Built in damper on the crank pulley and a lightened water pump pulley,they look great!
    I used the stock alternator pulley.
    Install was a breeze,all hand tools,ok some big ones,plus a puller.
    Had to dismount the fan but nothing hard at all.
    Now the bad news..............
    The way I use my Marauder the battery voltage drops below 12v at idle.Here in TX we use our headlights and A/C at the same time.Also even with the A/C fan on low sitting at a light with the brakes on the voltage drops below 12v.
    I don't have the kind of relationship with my dealer to go in and ask them to raise my idle to the 900rpm it would take to get my battery to charge.So it looks like the pulleys will be coming off Saturday.
    You guys with chips,or thinking about getting one from Dennis go ahead and ask him to raise the idle,it will help keep those gauges lights from blinking at you,even stock,with pulleys mine look like strobe lights.
    Live and learn I guess.
    cyclone:
    Before you remove the pulleys, do you really spend that much time idling at stoplights with all your accessories on? Even if the voltage drops more than normal, as soon as you accelerate even a little, the voltage should come right back up...I can't imagine it stays down long enough to affect your battery charge.
    Try this?...have your friendly local mechanic put a load tester on your battery, and record your results...drive the car for a week and have him test it again, see if the result indicates a slow draining of your battery. I bet it won't...
    I have to say I have not experienced this with the pullies. And my idle is at around 700, certainly not 900. I have no fluctuation in power with all accessories on at idle. And, I can't see how the pulley set could make any difference when the alternator pulley is not changed.
    Also, there was an immediate "seat of the pants" increase in power after they were installed.
    (NOTE: I still have stock VOLT gauge and it does not go below 12, but who knows since it is mainly an "ON/OFF" gauge)
    Sorry to hear they are not working for you.
    TX
    Well yes I do spend a lot of time idling.I pick my kids up from school,10 minutes at idle with the A/C on,hey its been over 90 here,then drive to another school and 10 more minutes.
    The pulleys change the car from one that gave me nothing to think about to one that REQUIRES monituring.
    Maybe I sound a little whinney about it but I've had cars that required ALOT of care and feeding and I think I'm over that now.
    To keep the voltage above 12 I rest my foot on the throttle,1000 rpm and alls well.
    I can report that the pulleys don't cause the engine to overheat.
    Oh and after a day at work in the sun all day the ONLY position on the fan switch is HIGH!!!
    Even without the lights the idle rpm has to be about 900 to keep the voltage up.
    TX
    Note I didn't say I getting rid of them.
    I'll put it back stock then go in and have the idle raised.
    Oh for the days when I'd be just a screw driver turn away from perfection.
    Sorry, man...your original post makes it sound like you were removing them permanently...
    Still, though, if you take them off, then go to the dealer to have the idle raised, isn't that gonna be a little suspicious, too?
    And doesn't raising the idle void the warranty?
    San Diego California
    not if the dealer does it....... IMHO
    "From the forest itself comes the handle for the axe"
    He's here! Carson James Mo--our 1st
    Born 6/02/2005
    Member Windy City Marauders
    1988 Mustang LX notch
    5.0 5 speed
    Engine by Total Performance
    GONE rear ended by a douchbag on his phone
    1990 Mustang LX Notch bought from the original owner
    2006 Dodge Magnum R/T (hers)
    (\__/)
    (='.'=) This is Bunny. Copy and paste Bunny
    (")_(")* into your signature to help her gain world domination.
    Put a piece of tape over your voltage gauge, don't look at it. The car is not in any danger of killing your battery....I promise!
    18psi pulley
    Billet Oil Pump
    ARP Bolts and head studs
    Snow Methanol Injection
    3500 Stall Converter (PI)
    Stryker 340 Fuel Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Lawrence Twp., NJ
    cyclone03: If your sitting at school for 10 min. and the MM is in netural than your battery will/should be ok? Do what RF said and run it for a week and recheck the battery..................
    Member # 383.
    2003 Marauder Black.
    Build 8/13/02
    Launched 9/28/02
    Sold May 16, 2018
    #3,646 of 7,839 black '03
    WolfeBros Guest
    Todd and all. The stock Voltmeter is very accurate from 10 volts to 16 volts. What you see is what you are getting unless the gauge itself is FUBAR. I know because I bench tested it with a very accurate Digital Panel Meter and Power Supply.
    Now the Oil Pressure gauge IS a different story......crapola as we all know. For those that don't know.....do a search here on the BBS on gauge.
    Thanks Wolfe...anyway, I don't go below 12...so if it works from 10 up...then I'm not having any loss with the pulley set.
    "Why don't you just make 10 louder"
    "Cause...................t hese go to 11"
    WolfeBros Guest
    If it doesn't stop raining out your way you will need a depth sounder.
    My next mod from Dennis...he's fabricating a propeller!!!!
    TX
    Back in the day when you dropped the trans into gear the idle would drop.
    With the computer as the car idles in park the RPM drop down to about 600 or so.Back into gear and it's still 600.
    Warm your car up and check it your self.
    Heart of GA
    cyclone03,
    Seems strange to me that your voltage is affected if you kept the stock alternator pulley. Something else must be wrong. Weak battery? Failing alternator?
    Or am I missing something?
    04 Marauder 300A - Dark Toreador Red - STOCK - 1 of 980
    Build date: 11/17/2003 - Delivered: 03/24/2004
    Heated Seats - CD Changer - Trunk Org. - SS Inserts - JLT CAI - McGard Locks
    Gone but not forgotten...
    03 Marauder 300A - Black
