Results 1 to 13 of 13
Thread: What to Look For In Purchasing Used Marauder
    Aug 2013
    Northern, IL
    Hey guys,
    I've been looking at Marauders since I sold my pickup. Is there any particular things to look out for in these cars before buying? I know with my truck I had to look for vacuum lines disintegrating, worn out ball joints, throttle position sensor and such.
    I live in a the Midwestern US but, I'm looking in the Texas area to avoid getting a rusty one and find even more possible problems.
    Oct 2012
    Oak Harbor, WA
    Dropped valve seats, slipping transmissions, inop EATCs, inop blower motor resistors, inop blend door actuators, stripped adjustable pedal gears, inop heated seats, inop sunroofs...these things are loaded with issues...
    ~Jon Barstow
    *2004 Mercury Marauder
    *1979 Jeep Cherokee
    Nov 2006
    Union City, CA
    Quote Originally Posted by H_M_T_81 View Post
    EATC (you can replace your own o-rings with the help of people here), BCM and LCM (you can have repaired and install yourself), and Blend door motor (you can buy a new one and install yourself but I hear is a PIA)
    Aug 2013
    Northern, IL
    If the valve seats were dropped, surely the car wouldn't run very well, would it? Also, how common is the valve seat issue?
    I'm fairly certain most if not all modern cars have damper actuators, are these more prone to fail? What about the blower motor resistor?
    I heard the CV's have heater core problems, I would think the same on the marauder, right?
    Lemme set things straight.
    MMs do not have dropped valve-seat issues commonly. Yes, it has occurred, but is not common.
    Blend-door actuator failure is fairly common across the whole Panther plaform, not just with the Marauder. The part is inexpensive, but the labour to replace it sucks.
    Panthers with EATC, which includes all Marauders, do not have a blower motor resistor, they have a BCM...Blower Control Module...which does experience failure and is a semi-PITA to access, but the repair is simple and a replacement module (if needed) is relatively low-cost.
    I have not heard of heater cores being an issue.
    The adjustable pedal issue is pretty much resolved thanks to the Curless Cure.
    Feb 2012
    harrison twp,mi
    floating center caps
    no really, i look for noisy engines ,smooth shifting transmissions, interior and body damage.
    obviously functioning controls, lights windows etc.
    if there are any doubts pay a mechanic to do a once over. usually 50-75 bucks.
    good luck
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    May 2012
    Fairfax, VA
    I love my MM, but these things have lots of little issues. Not all are a big deal or should prevent a purchase.
    Good luck.
    (Sold ) 2003 300A Black/Black.
    BC4E dead pedal - JLT intake - Jmod - Rear cat delete - Lowered - MuscleMerc cooling mod - TCE SS brake lines - drill/slotted rotors - red stock calipers - 410s - Badgeless grill - Custom rear badge - JLT oil separator
    facebook.com/bradtaylor33
    Jan 2013
    Continental Acres
    Remember, eventhough they are special cars they are just cars. There are no normal issues or even the unusual issues with these cars that the very knowledeable and crazy people on here can't help you fix. Most times in person depending on where your at...
    May 2012
    Fairfax, VA
    Quote Originally Posted by L.Mark View Post
    Great point right there. I've resolved most issues I've had with the help of MM.net.
    Aug 2010
    Southern NJ - Exit 4
    Quote Originally Posted by 93flareside View Post
    Hey guys,
    Big smiles (and empty wallets) are the most common defects.
    Aug 2013
    Northern, IL
    Quote Originally Posted by WhatsUpDOHC View Post
    Perfect!
    So some moderate HVAC issues but, nothing mechanical to be worried about. Just keep up on regular PM stuff. Sounds like my kind of car.
    Oct 2010
    Regular maintanence and you will be fine, if it breaks fix it asap and keep it movin.
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Jan 2006
    Mi.
  1. Things to look for when purchasing a Marauder
    By Paulie C. in forum Community Discussion
    Last Post: 07-03-2013, 10:28 AM
  2. Purchasing a Marauder in the near future.
    By Timw286 in forum Community Discussion
    Last Post: 05-13-2011, 05:54 PM
  3. Purchasing an out-of-state vehicle questions.
    By Embassy in forum The Lounge
    Last Post: 02-28-2008, 01:08 PM
  4. NYPD purchasing 50BMG rifles
    By BillyGman in forum The Lounge
    Last Post: 08-27-2005, 06:08 AM
  5. Replies: 3
    Last Post: 03-08-2003, 04:19 PM
