Results 1 to 11 of 11
Thread: big pipes or not
    Nokomis,Florida
    Question big pipes or not
    I HAVE A BONE STOCK MM. AND I WOULD LIKE TO PUT HEADERS, TRICK SENSORS, AND H-PIPE WITH FLOWMASTERS BREATHING THROUGH 2 1/2 PIPES TO THE TAIL PIPES. THE PIPES ARE 2" BEFORE MUFFLERS AND 2 1/4 AFTER MUFFLER TO TAIL PIPE RIGHT NOW. ANY INPUT WILL BE GREAT
    mermar:
    STOP SHOUTING!
    Seriously, it has been said in a couple of threads (do a search) that using big pipes may gain you some HP in the upper revs, but you'll lose a bit down lower, where the DOHC motor is already a little deficient...it had also been said that unless you make major changes to the heads and intake, or install a blower, the stock exhaust system is plenty adequate, so unless you want to change the exhaust SOUND, save your money...
    TripleTransAm Guest
    Originally posted by RF Overlord
    ...using big pipes may gain you some HP in the upper revs, but you'll lose a bit down lower, ...
    Does this apply for bagpipes too?
    Why are you asking me? I heard SARGE was the one with the big pipe(s)...
    D'OH!
    Nokomis,Florida
    sorry about the shouting RF, and thanks for your input. all in all i would like to have a throatier sound. you know something to really p--- off the neighbors when you leave at 5:45 in the morning
    Matt Creager
    #1
    -03 Black-
    Build date 5/30/2002, purchased12/10/2002, trunk org.Denso plugs,180 thermo,DR exhaust,DR tuner,Addco rear sway bar,Flowmaster 40 series, 2 1/2 exaust, Megs delete tips extended 1" past bumper, FMS 4:10's, Steeda under drive pullies
    #2
    03 Black 250k miles stock not for long though
    You can nice a nice, throatier sound by just replacing the tips with the so-called "pre-production" units, that have no baffling...or so I've been told...(I like the sound of mine the way it is)...another trick is to replace just the mufflers with either RaVin 55s, or FlowMasters (not sure if it's 40s or 50s); Fourth Horseman has FlowMasters, and a fair number of members have the tips, so hopefully they'll chime in...
    Hiram, Georgia
    The pre-production tips and a few thousand miles make for a nice sound out of the stock pipes. I hear the headers sound sweet too, but I have not heard them yet, but hope to REAL soon!
    MSR7878 Guest
    Just for fun I had my exhaust guy remove the mufflers and put in "eliminator" pipes, That with the stock tips makes for an awesome low RPM rumble and a "scare the neighbors" full throttle roar. I am really enjoying the sound but will bo with Flowmasters when I grow out op the straight pipes
    Jul 2003
    Virgo Super Cluster
    Does loud universally mean lower restriction and thus more power?
    Does quiet always mean higher restriction and thus less power?
    I like the idea of a MM slipping stealthfully to the line pulling away silently like it was sliding down a steep hill on ice with the opponent huffing hard, scratching his head.
    I like sneaky power.
    Dave
    TripleTransAm Guest
    Not necessarily. Lots of performance exhaust systems are tuned to deliver a certain sound, but have no improvements to offer over a stock system. Besides, the term 'power' is deceptive... as RF mentioned, you can gain peak power numbers with open pipes but that peak will be so high up the range and you'll be sad to note how much low end you lost. Overall, I'd say performance suffered in this example.
    As a data point, Borla offered a system for the LT1 and LS1 F-bodies where one could tune the amount of exhaust going through a straight pipe and how much would go through the muffler, using some restrictor plates on the open exhaust side. Every single time a comparison was made, the car performed best on the 1/4 mile with a particular restrictor plate (I forget which one) but it just shows how some backpressure was good. And the system was obviously louder without the restrictor...
    MSR7878 Guest
    I probably did lose a little low end, but like I said this is a temporary thing. But you should see people look when I run up my MM, Not the best system, but it sure is alot of fun
