Results 1 to 15 of 23
Thread: Voltage Drop on Acceleration Issue
    Hey guys:
    I have a 2003 trilogized Marauder with an unusual issue & would like your opinions. Under heavy acceleration my voltage gage drops from 14.5 down to 12.5 & stays there for a few minutes. Then returns back to normal. The issue is intermittent & does not always happen. It also affects the performance of the car. Any suggestions on what to look for.
    Thanks
    Nov 2003
    Horntown, VA
    Quote Originally Posted by bones View Post
    Hey guys:
    Thanks
    This is normal - alternator is shut of at WOT by the factory program. They all do it.
    Plate - "EVILMERC"
    It shouldn't affect the performance of the car, It's a 12v system so 12.5v is enough to run everything fine such as an upgraded fuel pump and high flow injectors. What exactly happens?
    Lehigh Valley, PA
    Quote Originally Posted by 2007VistaBlueGT View Post
    When you go WOT, the computer disengages the alternator clutch so theirs less drag on the belt setup, freeing up a few HP
    thats whats happening
    2063/3214
    5377/7838
    McDonough, GA
    Not Right!
    Your voltage should not drop that much. I would first check your soldered joint where the original alternator wiring was extended for the alternator's new position on the PS. If the extension was crimped - remove the crimp and insure it is well soldered with a good flame.
    Also, I would put another voltage gauge on the engine to measure the voltage. 14.5 is a little high. Note that the engine will not run up much past 4,500 without missing in park. It is a factory PCM command to do that.
    Glenn
    Trilogy #124 SOLD - 8/2014
    11.80 @ 117.16 MPH: SSHS9
    1.74 sec - 60'
    443 RWHP/437 RWTQ
    "Stock Internal Engine" - Click Below
    Hiram, Georgia
    Low voltage on a fuel injected motor can lead to a blown motor, especially on a boosted motor.
    Jun 2005
    East Lansing, MI
    The clutch on the Alt. is not for acceleration, it is for decel. The EEC controls whether or not the Alt. charges...
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    Hiram, Georgia
    The more I reread the OP, the more I am concerned for you.
    This is not "normal" especially if it is lasting for a few minutes and noticeably affecting the performance of the car.
    Het the alternator tested ASAP or you are in danger of losing a motor. Low voltage = a dangerously lean condition!
    Jul 2009
    NH
    Worth checking your alternator and battery. You can pull the gauge pod and get a reading with a multimeter. Since you said the engine runs crappy though, im sure the reading is right.
    12.073 @ 118.43 (Nitto 555)
    Drag racers prayer:
    Aug 2007
    Tulsa, OK
    An alternator on a Trilogized motor doesn't have a clutch. It has a regular pulley, because the alternator is mounted backwards.
    Brian
    Purgatory, FL
    I would check with Lidio at Alternative about this.
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
    Sounds tune related. Maybe the alternator is still being shut off at WOT like the factory tune.
    NO
    Quote Originally Posted by RR|Suki View Post
    YES
    Quote Originally Posted by Filby'sMarauder View Post
    Brian
    YES
    Alternator clutch is to allow the alternator to momentarily 'freewheel' at higher rpms during an upshift when the engine suddenly slows from 6,000 rpm to @ 4500 rpm. It eliminates the belt chirp when the belt suddenly slows down the heavy alternator.
    It's like a bike's rear hub...you can drive it forward, but it freewheels when you backpedal.
    (That's why the reverse mounted Trilogy set-up requires a non-clutched alternator pulley)
    Engine computer can shut off the alternator's charging function at WOT to save on parasitic losses, if programmed to do so.
    Lot's of tuner's leave the alternator charging function on at WOT to avoid any potential drop in fuel pump function/fuel delivery.
    Most high HP cars even add a Boost-a-Pump to keep full voltage/slight overvoltage on the fuel pump(s).
    Your situation, because of the extended duration of the symptom, does NOT sound normal.
    Oct 2004
    Kentucky
    Sounds like what happened when my OEM alternator went out.
    As others have stated, I'd test it.
    1. Black Sunshine (2003A F.I.T #3) (SOLD!)
    2. 2004 SAP P71 (Gone)
    3. The 2001 P71 (Flying Snow). (Sold)
    4. The 1998 P71 Jinbei. (Sold)
    5. 1990 5.7L IROC-Z (Sold)
    Keeping a black car clean is not a hobby. It's a part-time job.
    Support the troops.
    Dec 2003
    New Port Richey,Florida
    Quote Originally Posted by Glenn View Post
    Glenn
    Do what Glenn recommends chech the wire were it is soldered. If that is not the problem it could be the voltage regulator failing at high RPM this happened to me in my Marauder. Does your battery light come on at all?
    also use a multi meter under the hood at the battery while car is running.
    Sunshine State Marauders
    David
    Trilogy Supercharger#145
    2003 Black Marauder Now Grabber Blue
    300A Born 08-28-02 #4360
    [B]2003 Black Marauder
    300A Born 10-18-02 #5613
    Totaled 08-13-10
    Marauderboi (Alex)(RIP)My Son 03-02-92 to 08-13-10
    [B/]
    [IMG][/IMG]
  1. Voltage issue...
    By whtknt2 in forum Shop Talk
    Last Post: 09-14-2009, 06:25 PM
  2. supercharger acceleration
    By mercurymarauder in forum Community Discussion
    Last Post: 05-09-2007, 09:50 AM
  3. Headlight voltage drop
    Last Post: 10-26-2005, 10:08 AM
  4. Unintended Acceleration
    By JTBusfield in forum Shop Talk
    Last Post: 02-16-2003, 07:46 AM
  5. Voltage Drop
    By Zack in forum Community Discussion
    Last Post: 12-22-2002, 07:16 PM
