Some people say it's no change in the stock to modified. Well I'm here to tell you it is. The heat sink in the modified version is a lot bigger. That's the part with the coiled wire.....
2003 300A Black MM
FRPP ALUMINATOR MOTOR 10:1
STAINLESS WORKS LT HEADERS
ADDCO FRONT & REAR SWAY BAR
MONROE HD QUICK STRUTS FRONT
QA1 ADJUSTABLE REAR SHOCKS
Neat! never took mine apart too see what was inside, thanks for the pics!
601rwhp 592rwtq @19psi
Benefit to the modified one?
2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
2003 300A Black MM
Where do you get it from?
18psi pulley
Billet Oil Pump
ARP Bolts and head studs
Snow Methanol Injection
3500 Stall Converter (PI)
Stryker 340 Fuel Pump
45 lbs Injectors
4:10 gears
K&N Air Filter
Factory Spoiler
Widened Wheels
Nittos
170 deg thermostat
SS Inserts
Trunk organizer
Ur darn right theres a difference! When running stck one with my set up twice it died on me in summer once I changed over it never happened once.
________________
Marauderless
STAY TUNED!!!!!!!!!!
Any of you want to sell me your stock 1? I'm going to just buy the parts and do it myself. Just to lazy to go pull one from the junkyard.
Sent from my SPH-D710 using Tapatalk
04 SB MM RIP 4/24/09
03 SB MM (the new girl)
Mods: K&N CAI, 180° stat, SW headers, custom 2.5" h-pipe exhaust from headers to tips w/Dynomax VT mufflers, Part of the Art Carr Stage 2 tranny kit, rebuilt with Alto Black bands and clutches, deep transmission pan, big ass trans cooler, PI 3.5k rpm Triple disk TC, Dynotech 4" driveshaft, Metco Drive shaft loop and rear CA's, Addco front and rear sway bars, just a bit of powder coating, stock size performance brake upgrades, QA1 shocks in the rear with KYBs in the front, and replaced every stock suspension bushing. Tuner's Inc tuned 298 rwhp/306 rwtq.
2003 300A Black MM
My Marauder I just picked up does not have a boost-a-pump. Doom was asking me why it has no boost-a-pump and wanted to know if the FPDM was modified, so I asked Zack, whom I bought the car from. He told me he did not have to modify the FPDM or install a boost-a-pump while running 2 ford GT pumps because he put in a return style fuel system with the Terminator long block.
SEMPER FI From York, Pa
2003 300A Black MM
The donut thing is not a heat sink, it's a toroidal transformer of some kind...possibly used as a choke to suppress transients when the pump is switched off and on.
2003 300A Black MM
