After a two day rainstorm, I noticed tiny pimples on my hood. Bad paint prep? Will be taking it to paint shop this week. Any ideas/advice?
Clay bar and see if the pimples are on top of your clear coat ?
I use the clay bar a lot, it will even pull paint overspray off the car and give it a smooth surface
Was the hood recently painted?
STAY TUNED!!!!!!!!!!
Did you get hail?
Can't stop the signal...
can you put some pics up? The only time I have seen similar to what you describe is when paint work was done a while back and there was water in the air system. But without knowing the cars history myself I'm only guessing . how long have you had it and it seems you noticed it right after the rain storm?
Sent from my Nexus 5 using Tapatalk
Sorry for starting a guess-fest. Here is a photo of the hood.
Trying to see via cell pic, that looks like rust popping thru. Bad paint prep or poor metal quality...
WLB
#2912 of 7093
Conceived 8/6/2002
Delivered 9/19/2002
Adopted 8/10/2011
Pioneer 6x8 Front
Legacy 600w 6x9 Rears
JL 6.5 SubWoofer
DR Deep Aluminum Trans Pan
Mo's Dyno Tune
Gorilla Nuts - The System
I would run from da shop who painted that
Not saying the orange peel is horrible, but the clear coat should have been there to prevent the paint from sucking up the water. Just a guess, try popping one of those pimples and see if water comes out..
It will need to be completely stripped to bare metal, metal etched,primed painted and cleared
Sorry for your luck
Use good soap and moisturizer.
What he said. Unfortunately whether it's rust, water or both something is trying to get To the surface from the bottom and causing separation. Hopefully the hood is the only real problem area on your car. Just make sure wherever you go makes you feel completely comfortable about the repair process or do not use them. Best of luck with it .
Based on age, it could be going through puberty...
I remember a UAW employee describing how the painting process was compromised in a few ways.
The first was a "One Shot" method where the sheet metal has a electrical charge and the Paint & Clear were applied simultaneously.
The other issue was a prep work fopa , where they did not entirely clean the painting equipment from the solvents , thus "watering down" the paint.
He said , at the same time of manufacturing, the Harley Davidson F-150'$ were getting the works!
He said, " We should have been so lucky to have the same level of quality finish, for the Marauder!
Sent from my XT1096 using Tapatalk
I had a complete strip / repaint in 2012, those little blisters turned to cracks on the top panels .
The top of the car had a quarter size rust spot eventually.
