Noticed that the master cylinder was leaking. 60k on the car currently. Any suggestions on best place to get a replacement. Something in between dealer and auto zone? Will install myself.
Performance
Dress
LOC: Clermont Florida
It could not hurt to see what the dealer will charge.
(#6178 in black per FPIC)
Rest In Peace:
Paula Babineau 1/9/67-8/2/11
Rex Weinbender
Peter
Funny this thread popped up. I had a brake flush done this weekend with new brakes installed and something still dont seem right. I have about a 1/4 free play before I start feeling pressure. I think I may need a master as well.
2003 MERCURY MARAUDER 300A
Build Date
5/31/02
Sequence#
#363 of 7839 Black Marauders
Dyno tested power
Best 1/4 mile time to date
12.456@109mph
Visit my Garage
Blackened300a's Garage
Bench bleed the new one before you put it in to make sure there is little to no air added to the systemto make it easier then leave the bleeder screws open on the calipers after install and flush out all the old fluid in the car to remove all moister build up in the fluid.
Break fluid does build up moister and most break lines rot from the inside out due to this. So any time the system gets something replaced it is best to flush it all out.
Fuel systems and Break systems are basicly the only things that do build up moister.
2003 300A BLACK DD
Sequence # 4569 of 7839
Silver Inserts / K&N CAI / Drilled - Slotted Rotors
DR Xcal2/Under drive pulleys (thank Rich)/180 T-stat
EMP water pump / Denso irridiums (thanx Rich)
Diamond Plate Radiator Cover and Air Dam, made by and broken in by magindat.
Custom Embroidered SB Head Rests (Thanx Rich & Rex)
Running with no mufflers, makes me sound fast!!
Upgraded Sound System (John's Stereo)
-Pioneer AVIC-D3 w/ XM & iPod
-Pioneer Premier Speakers
-MTX TC3001 Amp
-MTX 10" Sub w/ Custom Box and LEDs (magindat)
adopted 6/12/07 - 20,956 Miles
SOLD 2/23/13 - 73,286
Contemplating a battery handle delete
2003 300A BLACK DD
-MTX TC3001 Amp
Performance
Dress
The local dealer wants $214 for a new Ford unit and Napa wants $137 for a new United unit. Is the Ford marking worth $77??
Performance
Dress
http://www.rockauto.com/catalog/x,ca...,parttype,1836
interestingly, the "Dorman" brand remans have two different Part #'s, one for W/ Traction Control, one WO/ Traction Control.
I didn't realize traction control would make a difference...
Trilogy #112 (self installed)
12.99@106.2mph (for now)
You guys know more about this then I, but: I read somewhere that when dealing with a leaking master cylinder you need to look closely at the vacuum booster as well. The leaking fluid will damage the vacuum seal on the booster and lead to repeat failures. Is this accurate?
2003 300B
VIN: 677166, #6738 of 7839
built: 2/13/03
wrty start: 5/28/03
84,197 on 02/21/08
95,776 on 02/21/09
109,301 on 02/21/10
121,447 on 02/21/11
125,925 on 02/26/12
130,375 on 01/01/13
134,831 on 2/4/14
149,441 on 2/24/18
Dark Blue Pearl, #128 of 327
