Results 1 to 3 of 3
Thread: Traction control 300a
    Jan 2006
    Owensboro, Ky
    I pulled the cover from the dash today and found wiring and a connector where the Traction Control should be located. Why would I have wiring for T/C if it wasn't originally offered on the 300a?
    If I gave a crap about gas mileage I would own a bicycle. With my luck I may have to go bike shopping tomorrow.
    Black '03 300a SOLD. 1993 Crown Victoria LX. 5.4L Supercharged/6speed. SOLD. New ride:
    Lehigh Valley, PA
    you can put T/C in if you wanted to.
    Ford does this in all the panthers. Like im sure your aware in P71's you can add cruise control just by getting the correct steering wheel and plugging in the buttons.
    to add T/C you would need to replace the ABS control box with the ABS/ Traction Control box
    2063/3214
    5377/7838
    Jan 2006
    Owensboro, Ky
    I didn't think it was available. Ok then. That makes since to me and no I don't want it. I was just curious. Thanks
  1. Traction Control Switch.. question
    By Architect in forum Shop Talk
    Last Post: 10-10-2008, 06:26 AM
  2. MM options:
    By Peter in forum Community Discussion
    Last Post: 05-22-2008, 09:53 AM
  3. A 2003 300a With Traction control????
    By 1of327 in forum Community Discussion
    Last Post: 09-12-2007, 01:07 PM
  4. Z&M Control Arm Install Detail.....DUW!!!
    By MM2004 in forum Steering, Suspension & Brakes
    Last Post: 08-13-2007, 10:53 AM
