Results 1 to 13 of 13
Thread: Trans Rebuilt
    Jul 2007
    MB. Canada
    Smile Trans Rebuilt
    Hi All.
    Posting that the Rodder is back on the road & trans is fully rebuilt & with stronger parts & one year warranty.
    Next is to install the
    AUTOMETER dual A-Pillar pod with trans gauge & ZEX gauge
    & METCO Driveshaft loop when it arrives from ADTR next week.
    I won't have much time to test it out cus time to winter store it soon.
    The MM WILL be ready for Louisville & a trip to Mo's for a few more mods in April.
    Trilogy With Comp Cams Stage 3 Sound's
    https://www.youtube.com/watch?v=GUIRJ1zGhSA
    https://www.youtube.com/watch?v=AAUWZ9f8gXw
    https://www.youtube.com/watch?v=mrPUl529gog
    https://www.youtube.com/watch?v=KvfRjhiGT4w N/A Sound
    Dyno By "Mo's Speed Shop",Dallas,Georgia https://www.youtube.com/watch?v=VqxN3FjWd6s
    445 RW/HP @ 398 Torque S/C
    Jeff Doing a Traditional Burn Out At "Mo's Speed Shop"
    https://www.youtube.com/watch?v=nCyKuC5heAI
    So Far Best Run 12.84 @106 MPH https://www.youtube.com/watch?v=dlA-0vB0HwU
    Big "Thanks" To Gerald,Derek,Bill & Harrison
    "Thanks" Martyo & Jeff
    #6486 of 11,052 03 300B In Black
    Oct 2010
    That's a hell of a rebuild, i thought you already had a built trans
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Jul 2007
    MB. Canada
    Smile
    Quote Originally Posted by MOTOWN View Post
    It was rebuilt a year ago but a few weeks after the Aug dynos the trans started to slip a little but thought nothing of it till driving to Vegas when it failed.
    Cause:
    The B&M shift kit wasnt pumping enough oil causing the 3rd 4th to fail,Overheating the converter.The converter clutch system was found to be to weak & not adequate for the power & heat increase.
    But now the trans has better stronger,up to date parts.
    The big test is Louisville & to Mo's in April & some ZEX track runs in May.
    Feb 2012
    harrison twp,mi
    So they screwed you IMHO
    Because they didn't cover the trans under warranty.
    You told me it was built for 500hp originally.
    Don't be a pushover, just sayin.......
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    Jul 2007
    MB. Canada
    Smile
    Quote Originally Posted by lji372 View Post
    Part of the trans work was under warranty locally,But not the Converter & other parts I ordered from TCI which they recomended & clam can hold 500 + HP.
    The local shop contacted TCI & couldn't get any where with them & went to a different source.
    Took 2 weeks for the shop to find the right combo & with a full warranty.
    Quote Originally Posted by WPG_Merc View Post
    Cause:
    I hope you didn't re-install that, or any other, shift kit.
    J-mod FTW!
    Feb 2012
    harrison twp,mi
    J-mod FTW!
    How could they have got him to buy it and not install it
    (it was the same trans shop the second time)
    Gordon as long as your happy
    Smile and Nod
    I love THIS bar
    Nov 2013
    CT, MA
    B&M and TCI have never, ever been good trans parts or convertors in cars I've owned or known, over 35 years.
    Just like Crane Cams. Junk.
    I hope they used other vendors on this build.
    2004 SILVER BIRCH/BLACK PAINT
    DARK CHARCOAL NUDO LEATHER
    #400 of 997 (SOLD)
    2004 CV LX SPORT
    2004 300A MM BLACK
    1 OWNER CAR, NO OPTIONS
    DAILY DRIVER
    2013 DAYTONA R/T
    SUPER TRACK PACK
    DAYTONA BLUE PEARL
    #1763 off ~2100
    NOW WITH A 392 & 3.73 posi!
    Oct 2010
    Quote Originally Posted by chief455 View Post
    I've used both , and they are both garbage, not worth the money.
    ITS ALIVE !!!!!!!!
    Jul 2007
    MB. Canada
    Thumbs up
    The B&M shift kit was installed in 09 when the motor & trans were stock,But it wasn't replaced or modified on the first trans build & worked fine.
    The B&M shift kit & converter failed burning gears a few weeks after the degreeing & ZEX dyno in Aug as the MM is now at a higher matched HP & torque level.
    I asked other local trans shops about the Jmod in 09 & the one that did the work & 1.they don't know what a Jmod is 2.they don't want to be accountable if it's done wrong.
    Transgo Shift Kit T76171E
    http://www.transgo.com/products.php?...1&prod_start=1
    BM SERIES Bracket Master 9.5"
    http://www.tcsproducts.com/products/...2800-3500-rpm/
    9.5"
    I hope It's a better combo,but I would like to go S/C & forged at some point but right now I'll get the MM ready for it.
    Jan 2013
    Indiana
    Honestly, they charged a lot of money and didn't upgrade any of the hard parts.
    On all my supercharged transmission rebuilds I upgrade the intermediate stub shaft with a piece machined from 300m alloy. its also a good idea to upgrade the mechanical diode one way clutch to the newest version that has more locking teeth. Its much stronger than the earlier design and can withstand more abuse under the full throttle pulls during 1st and 2nd gear. Lubrication improvements are a MUST, for any rebuild and really improve lubrication to critical areas. Since you are running Nitrous in your car, 300M shaft is required in my opinion.
    The only thing worse than a TransGo shift kit, is a B&M shift kit. As Jerry has pointed out several times, these kits are trying to mechanically override internal transmissions functions that are controlled by the ECM.
    I rebuild AOD/AODE/4R70W/4R75E Transmissions, check out my Facebook page for my latest project; https://www.facebook.com/pages/North...48414635312478
    Indiana
    I worked as a cam grinder for crane cams when i was younger.... Our chinese garbage rough castings were unbelievably porous and whenever we got a really bad batch, steve crane would just tell us to keep grinding away until it looked good, to hell with correct base circle or advertised lift... I think the company went to **** when harvey retired....
    Jul 2007
    MB. Canada
    Thumbs up
    Quote Originally Posted by 88grandmarq View Post
    Thanks for the info.
    Right now it's as far as the MM will go HP wise.
    Next big $$ step is forging & S/C & may take time to plan it out,The big prob is local shops here are not repeatable to build or tune one.
    It's why I like to visit Mo's after an event 1,735 + mile's away for upgrades.
  1. Bought/Rebuilt my first Marauder
    By Zeph78 in forum Welcome Forum
    Last Post: 11-02-2015, 06:23 AM
  2. My Rebuilt Engine.......
    By Marauderjack in forum Community Discussion
    Last Post: 05-11-2015, 05:14 AM
  3. Rebuilt trans issues
    By detrailers in forum Transmissions
    Last Post: 04-12-2015, 05:56 AM
  4. new well rebuilt engine
    By jfclancy in forum North Texas Marauders
    Last Post: 04-22-2014, 02:20 AM
  5. Tranny being rebuilt at 31,000
    By MonsterD in forum Community Discussion
    Last Post: 11-22-2004, 04:36 PM
