Results 1 to 7 of 7
Thread: Flexplate Shield
    Flexplate Shield
    Here's a couple of pics. I may need to make a minor mod for dipstick brace mounting, I'll test fit before installing and take pics with it on the tranny outside of car.
    Didn't fit... I believe the one they sent me was for a AODE 5.0, the top two bolt holes lined up ok but the others didn't. I'll be contacting them for refund/replacement next week.
    Hiram, Georgia
    What is your thinking behind installing this?
    If the flex plate shatters the shield will prevent it from entering the car?
    Hiram, Georgia
    Quote Originally Posted by fastblackmerc
    I know what they do, but they are probably over kill for our cars. That's what prompted my question.
    Just testing it out for the benefit of all. At some point we may need it to comply with rules. I believe you're already illegal (not for this, for tranny shield) since you're in the 10's. I believe you can use a blanket instead of a tranny shield.
    Here's a list of rules I copied from MPH forums:
    Mandatory at ET (or quicker) Item SFI Spec
    13.99 Drive shaft loop (slicks)
    13.99 Helmet (Snell 90+)
    13.49 5-pt harness (convertible) 16.1
    13.49 Approved rollbar (convertible)
    13.49 (IHRA) Drive shaft loop (slicks)
    11.49 Drive shaft loop (street tires)
    11.49 Approved flywheel & clutch (manual transmission) 1.1, 1.2
    11.49 Approved protective jacket 3.2A/1
    11.49 Approved roll bar for all vehicles
    11.49 Approved 5-pt harness 16.1
    11.49 Approved flywheel shield (manual transmission) 6.1, 6.2
    11.49 (IHRA) Approved mounted fire extinguisher
    11.49 (IHRA) Approved flywheel shield (automatic transmission) 4.1
    10.99* Approved roll cage (convertible)
    10.99 Approved harmonic balancer 18.1
    10.99 Approved aftermarket axles
    10.99* Approved transmission shield (automatic transmission) 4.1
    10.99 (IHRA) Competition License* Class D
    9.99 Approved flexplate & shield (automatic transmission) 29.1, 30.1
    9.99 Approved roll cage & window net* 27.1
    9.99 Master cutoff switch
    9.99 Competition License Class 4, Cat. C
    9.99 Chassis Certification
    9.99 Approved jacket/pants/neck collar/gloves* 3.2A/5, 3.3, 3.3/1
    9.00 (IHRA) Roll cage & window net
    8.99 (IHRA) Competition License Class C
    8.49 On-board fire system
    8.49 to 7.50 Chassis certification 25.4/25.5 (3600#)
    7.99 (IHRA) Competition license Class B
    7.49 & quicker Chassis certification 25.1E (2800#)
    7.50 & slower Chassis certification 25.2 (3200#)
    7.49 Competition license Class 3, Cat. C
    IHRA Pro Stock Competition license Class A
    150mph + Parachute required
    * Also required for 135 MPH or faster
    ** Also required for 180 MPH or faster
    Hiram, Georgia
    Interesting.....
  1. The Shield Season Finale
    By LVMarauder in forum The Lounge
    Last Post: 03-22-2006, 08:33 PM
  2. Modified JLT Heat Shield
    By DEFYANT in forum JLT Performance
    Last Post: 02-09-2006, 07:30 AM
  3. JLT Heat shield coming soon!! Pics
    By Tucker in forum JLT Performance
    Last Post: 02-18-2005, 04:51 PM
  4. Radiator Site Shield Label
    By TheDealer in forum Community Discussion
    Last Post: 07-09-2004, 10:05 PM
  5. Fuel tank shield
    Last Post: 01-28-2003, 10:16 PM
