Good you can start the Q&A to stalling the convertor or flashing it.
2003 MERCURY MARAUDER 300A
Build Date
5/31/02
Sequence#
#363 of 7839 Black Marauders
Dyno tested power
Best 1/4 mile time to date
12.456@109mph
Visit my Garage
Blackened300a's Garage
Here is how I got the most out of my stock TC....
Sit at light with left foot firmly on the brakes...
Right foot on Accelerator to the tone of 2200-2600 RPM...
Right before light turns green release brake under left foot...
then try pushing gas peddle through the floor board...
Caution: Do not be chewing gum, it may be forced to the back of your head.
it's just a part of the car. it isn't some special gizmo that has a magic button. nm, you've posted too many times to be serious. Although, I have found that cruising at 25 then punching it is the best gear change
That's the idea. The higher stall speed converter attempts to ge the engine rev closer to the power band before launching. Stall speed is the speed at which the turbine and the rotor (the spinny part and the drivey part) are turning the same speed.
When the converter 'flashes' it is basically like a clutch drop. It's a little slower (split seconds), but much better (clutches can't multiply torque). The fluid is quickly forced to move the two halves of the TC at the same speed. During this 'flash', (very oversimplified) the TC reaches it's max torque multiplication factor (which is like 1.9 or so stock), so for that instant you are cramming twice the torque (400 or so at 2500 RPM) through the drive line for an awesome (gum swallowing) launch.
This phenomenon increases as one increases the stall speed (closer to peak power/torque) and gets higher torque multiplication (Precision Industries is 2.5), hence the reason people so love the PI 3000 and 3500's.
2013 Ford Taurus SHO
#1649
boi
Or you could get a Stallion and use your stock TC as a doorstop.
Might be heavy enough to anchor a small boat, too.
Self-importance is our greatest enemy. Think about it - what weakens us is feeling offended by the deeds and misdeeds of our fellowmen. Our self-importance requires that we spend most of our lives offended by someone. -- Carlos Castaneda
nice explaination, magindat. my dad explained it to me a while ago and it's about the same, but yours is a bit better
You wouldn't really be "hurting" your brakes. Just kind of pre-loading the TC, it's not like you would be doing a burnout or anything.
445rwhp/408rwtq - 12.6/110mph
DR Vortech NOIC #5
Sold
You bet Brutha...If yours is a rocket with just stomping the pedal...Then by pre-loading the TC...You will be sent into orbit...with tires smoking....YEEEHAAA!!!
ALOHA
'03 A Build Date 8/02
F.I.T. #6 ***RESURRECTED***
*444 RWHP / 401 RWTQ
*10 lbs. Boost
*P1SC1 ProCharger
Temps dropped into the 60's tonight and I attempted a TC flash launch and a TC stalled launch. Both set my rear tires up in smoke but the flashed launch let me spin all the way through first and some of second before the tires grabbed and bogged me down to take off, The stalled launch spun through first but bogged me down as soon as it shifted into second so its very possible that flashing the convertor is the stronger launch.
This test will have to wait for the track for rock solid proof and traction.
Build Date
5/31/02
Sequence#
Dyno tested power
12.456@109mph
Visit my Garage
